feels like power is gone
Old 01-14-2012, 11:10 AM
mbxmitch's Avatar
mbxmitch
mbxmitch is offline
Guys let me know if this sounds familiar.
Driving my truck it feels like it has no power ,like I have to really step on it almost like its sliding in a gear if you know that feeling. I just got a new trans so that I dont think thats it.could the rear be slipping?
also my exhaust is not complete so some of the high rpm noise might be from that
Old 01-14-2012, 11:35 AM
SCRebel's Avatar
SCRebel
SCRebel is offline
Is the trans broke in? You need to break in the trans before you dog it.
Old 01-14-2012, 11:38 AM
mbxmitch's Avatar
mbxmitch
mbxmitch is offline
Not ******* it at all, besides a new trans should be stronger then it ever is
Old 01-14-2012, 11:43 AM
SCRebel's Avatar
SCRebel
SCRebel is offline
Any codes?
Old 01-14-2012, 11:47 AM
mbxmitch's Avatar
mbxmitch
mbxmitch is offline
Originally Posted by SCRebel
Any codes?
I have no way of checking
Old 01-14-2012, 11:50 AM
SCRebel's Avatar
SCRebel
SCRebel is offline
Alrighty. What year truck do you drive?
Old 01-14-2012, 11:57 AM
mbxmitch's Avatar
mbxmitch
mbxmitch is offline
94 it has a 5.8 L automatic . my engine light was always on it needs an 02 sensor and the air pollution tube and a cat
Old 01-14-2012, 12:02 PM
SCRebel's Avatar
SCRebel
SCRebel is offline
That could exactly be your problem. The O2 sensor decides the air fuel mixture, b/c it tells the computer weather the engine is running lean or rich. The cat and air pollution tube, can hurt you on power too. If the cat is clogged, or if the tube is sucking in raw air.
Also you should have a EEC-IV computer, this is how you test.
Old 01-14-2012, 12:10 PM
mbxmitch's Avatar
mbxmitch
mbxmitch is offline
now if I replace my o2 sensor with out doing the rest of the exhaust work would that help a little? I can not afford the cat and all right now. it does smell like its running rich like I can smell gas standing next to it
Old 01-14-2012, 04:44 PM
SCRebel's Avatar
SCRebel
SCRebel is offline
Yes it will help, as long as the exhaust is hooked up. Are you in a state that test emissions? If not, I would just cut the cat off, and weld a pipe in its place.
My state doesn't test, so I cut the cat off mine, got rid of the smog, and the EGR is gone.
Old 01-14-2012, 05:05 PM
mbxmitch's Avatar
mbxmitch
mbxmitch is offline
I dont have a cat just two pipes coming from manifolds to the out end of a daul mufler .
Old 01-15-2012, 12:02 PM
SCRebel's Avatar
SCRebel
SCRebel is offline
ok. Is the tube for the EGR from the cat just hanging there? If it is you need to pinch and crimp it. Cuz every time the EGR opens (if that tube it just hanging there) its sucking in raw air. Which is bad for your motor and will make the engine run lean.
crazymut
11-16-2009 08:59 PM
snakedoc
07-08-2009 11:54 AM
randomhero1172
04-27-2008 01:56 PM
Quick Reply: feels like power is gone
