1988 Ford Bronco II Radiator Mounts - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 01-13-2012, 05:38 PM
RetNavO3 RetNavO3 is offline
RetNavO3 is starting off with a positive reputation.
Hi, All: I'm restoring an '88 Ford Bronco II and when I started removing the old-and-busted radiator support I noticed that the two mounts (RH and LH side) are way past being used up. I was able to find radiator core mounting stuff like the upper and lower cushions, mount bolts etc. but those two mounts don't seem to be out there anywhere I've looked.
So: Am I going to have to go on a junkyard hunt, see if the Rangers from that era have the same mounts and still go on a junkyard hunt (good luck with that) or have the pair fabricated somehow? Any other suggestions? Anybody have a pair of these laying around that are looking for a new home in a BII that's being brought back to life?
Here's what the two old ones look like:
Any guidance would be greatly appreciated.
Old 01-14-2012, 10:07 AM
Ford Bronco Radiator Mounts?
Hi, All: I went to the good old Jeff's Bronco Graveyard website and I notice they've got radiator core support frame mount brackets for the '80 to '96 full-size Bronco. Maybe these will work? It looks like the mounting holes for these are higher up than in the BII's but that's easily solved with a drill bit, right? (LOL!).
What do you-all think? Would these be a good workaround?
Thanks!
T.G.
Old 01-14-2012, 03:28 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Should be easy enough to make a pair.
Old 01-14-2012, 03:41 PM
Quote:
Yeah, I did some asking around and if I can't make the ones I got at Jeff's fit there are workarounds that can be done to me 'em fit. ;-) Thanks for the reply!
Old 01-17-2012, 12:15 PM
Ruffinit's Avatar
Ruffinit Ruffinit is offline
Ruffinit is starting off with a positive reputation.
Now would be a perfect time to change it over to the newer radiator and mounts? Just something to think about. The mounts and radiator on my '83 are in good shape, but if I was to refab, I'd look at going with the newer stuff.
Old 01-17-2012, 12:24 PM
Quote:
Exactly so. I'm putting in a new radiator and assorted other pieces while I'm doing all this. I'm going NOS as much as possible, so it's a bit of a slog but I'll get there. :-)
Thanks!
T.G.
Old 01-17-2012, 08:09 PM
Ruffinit's Avatar
Have fun. I really like the simplicity of my '84 (typo on the '83) and I read your post wrong for some reason.. I'm thinking of dropping in a 302 (non-injection) to it.
My '88 I liked because of the luxury of it. It was fully loaded. Still sitting out there.. Rusted beyond repair. It'll be going as soon as I pull the tranny and xfr case. It was a great ride. Check out the "broncoii4x4" website for some great info also.
WOOD FLATBED BUILD - 3D MODEL AND CONSTRUCTION PLANS RAY1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 418 02-20-2017 09:55 PM
Whats this fitting in side of oil pan ? Ken(Ark) Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 02-15-2015 09:02 AM
9" Axle Swap How To / Project Pictures - PIC HEAVY RAY1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-23-2012 12:49 PM
9 INCH REAR AXLE BEARINGS AND SEALS HELP ME PLEASE RAY1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-13-2012 08:35 PM
Need ID help , oil pan , motor mount plates Ken(Ark) Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 01-14-2012 08:56 PM
Tags
1988, 87, 88, 96, bronco, core, explorer, f150, ford, ii, mounts, pic, radiator, ranger, support, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
