rebuilt 5r110 locking up engine - Ford Truck Enthusiasts Forums
Old 01-13-2012, 05:16 PM
tay320c tay320c is offline
tay320c is starting off with a positive reputation.
Replacing 5r110 transmission with rebuilt. Torque converter was not secured to transmission and fell out in crate during 500 mile delivery. Trying to seat converter before installthe transmission it would only go in part of the way. Rebuilder drove 500 miles and replaced front pump said sorry about the mix up on the gear. I installed the transmission, flushed lines and cooler, replaced the inline filter, added 12 quarts of fluid as they required for startup, connected battery cables and started engine. Truck ran for 10 to 15 minute I raised the rear end and tried to run it through gears. Nothing happened. I check fliud still OK. I shut it down and it still showed no change in fluid level. Started it back up not a tire spinning, I gave it about 1600 rpm the trans start making a very high pitch building pressure as the tow/haul was flashing then started chocking the engine down finally killing it. Called the rebuilder no call until the next day. They said I needed to get it hotter and run it longer before putting it into gear. The truck start right up and in 2 minute choked the engine down. I restarted and engine just got tighter. Thought the batteries were dead at first but had them check and the engine will verly turn. I believe the fluid drain down over night and then built back up choking the engine. I put a scan tool on it and NO codes for trans or truck. What could be the problem. The first day temp was 55 in shop today 35. Any Ideas
Old 01-13-2012, 09:04 PM
Jimbob8's Avatar
Jimbob8 Jimbob8 is offline
Jimbob8 is starting off with a positive reputation.
I can't say this applies, but some flex plates have only 1 hole for the drain plug on the torque converter, if it's not right that will bind up engine. If that is right then you need to talk to rebuilder. Good luck.
Old 01-13-2012, 09:27 PM
It run to well for 15 minutes before it started building pressure. I believe it is something with the pump causing full lockup of converter. Thanks for the reply and your time.
Old 01-13-2012, 09:35 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Man this Tranney has been a Can Of Worms
God only knows whats wrong with it if they already got the front pump wrong
Who was the rebuilder???
And I agree its got to be the tourque converter I mean thats the part that allows the engine to idel when trucks at a stop
IDK about the flex plate having a drain hole for the TC
Granted the last TC I changed wasnt on a 6.0 but the TC itself didnt even have a Drain plug
Did you prefill the TC at all B4 you installed it?? I know it sucks to prefill and could take a day to get a quart in it but I always try and prefill them I figure anything is better than dry
will it run if you leave it in park or what????
when does it Bog the engine??
I agree sound like the TC maybe locking up
Old 01-13-2012, 10:40 PM
Yes I filled the torque with 3 quarts. Your right it does not have a drain that was with the 4r100. Thanks for the commment.
Old 01-13-2012, 11:06 PM
BLADE35's Avatar
So does it Bog the moter in park or just in Drive ??
Old 01-13-2012, 11:27 PM
It's locked tight, will verly turn over the engine. I thought it was the batteries but their fully charged with solid cranking amps. If he tore the gasket just below the pump would that cause this? They said it was tested but define tested and this pump was not part of the test. I know there are relief valve as well as control valves with springs in the pump. Could these be install wrong? If it has caused the TC to lock up this bad how do you release it or do you pull the tranny.
Old 01-14-2012, 12:31 AM
BLADE35's Avatar
So he tore the pump gasket and didnt have another?? I guess if it starts leaking you will know why
I woould double check the wire harness and verify no pins are bent corroded and fulley plugged in
And I wonder if the internal wire harness got plugged in right or got pinched or something. Might have to pull the pan off.
I think its a F**kup on the rebuilers end of things
IMO you should have been able to install it fill with tranny fluid and let it idel fill everything up with fluid and GO
that sucks hope you dont have to pull it back out
Old 01-14-2012, 12:34 AM
BLADE35's Avatar
Quote:
The TC is ment to lock at higher speeds for improved MPG
and is electronicaly controlled
But the TC shouldne be locked up in park or lower speeds
Kinda why I wonder about the wire harness
Old 01-14-2012, 04:31 AM
It could be the wiring to the TCC soleniod or the soleniod itself. I checked the connections twice but moving the harness during replacement it could have broke. Thanks for your time.
Old 01-14-2012, 07:55 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
I may be wrong but it sounds like an internal problem to me. Any strange noises, pump grind or the like?
Old 01-14-2012, 08:20 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
WOW! Where to start with this one...I guess at the first mistake.
You ran it for 10-15 minutes with only 12 quarts in it? There's your failure. That isn't enough fluid for the pump to always have fluid to pick up. You were running the pump dry for a long time.
The correct way to do this is put in 12 quarts and run it for ONE minute. This fills the torque converter. There is no need to add any fluid to the torque converter before installing it.
It can't be OK with 12 (maybe 15 if there really was 3 quarts in the converter) in it. It should be WAY low. Maybe it's reading fluid from the side of the dipstick tube.
That indicates that the pump is not picking up fluid.
That's when the pump seized.
Bull.
There were codes set when the tow/haul light flashed. Your scan tool probably can't read Ford transmission codes.
The next step is probably removing the transmission and rebuilding it. I think this one is toast.
Old 01-14-2012, 09:18 AM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
Mark is very good with helping us out with transmissions, I would listen to anything he has to say....
I would like to comment but its not intended to be a rude comment, wouldn't it have been easier to just go to ford and get a reman, and install it yourself?
Old 01-14-2012, 09:37 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
Absolutely.
Old 01-14-2012, 10:01 AM
They gave a lifetime warranty over Ford.
Sometimes the truth hurts and I did install it myself following their install sheet instructions. Still do not know why it stopped the motor then over night with the fluid still they same and start right up the next day but locked up the motor again. It seem the torque is dead heading or no exit relief back throught the pump. Will it drain down out of the TC overnight because this is a wet sump unlocking the TC? Thanks
Swap 4wd 5r55e tranny from 2001+ to 1998 ranger: DONE slvr00gt Ranger & B-Series 21 10-10-2013 10:35 PM
A4LD - 4R44E and 4R55E 96_4wdr Aerostar 6 12-13-2012 11:48 AM
1993 Aerostar A4LD no forward or reverse rhblakeman Aerostar 11 06-16-2012 03:25 AM
Did you hear about the new 6.8L V10 Rosson03 Excursion - King of SUVs 37 02-18-2012 08:41 AM
4r100 transmission slipping 4th gear only when cold? Bluesmokestack 1999 to 2016 Super Duty 6 12-10-2011 10:28 PM
Tags
4x4, 5r110, bad, converter, duty, ford, gasket, grinding, install, mount, pump, rebuilt, sale, seized, super, torque, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
