Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 01-13-2012, 03:28 PM
fg250's Avatar
fg250 fg250 is offline
2012 Ford F-250
fg250 is starting off with a positive reputation.
TRAILER DICONNECTED
I started my truck this morning after leaving the store and I got the trailer disconnected message for a minute or less, then it went away....anyone seen this?
  #2 (permalink)
Old 01-13-2012, 04:51 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
That's weird, did you accidentally bump the trailer brake controller? I can't recall what happens when you hit that with no trailer attached but I know something pops up on the screen...
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #3 (permalink)
Old 01-13-2012, 08:15 PM
fg250's Avatar
2012 Ford F-250
I don't think so, I think it's too far away for me to have done that. I have a friend of mine with an '09 chevy that was doing the same thing, and wound up having something replaced. I've driven it a few more times this evening and it hasn't done it since.?
  #4 (permalink)
Old 01-13-2012, 09:43 PM
nmhs nmhs is offline
Garage is empty, add now
nmhs is starting off with a positive reputation.
Mine just did that this morning when my passenger door was opened. Its a 2012 F250 crew cab.
  #5 (permalink)
Old 01-13-2012, 11:13 PM
Fawcett Fawcett is offline
Fawcett is starting off with a positive reputation.
Mine is doing it also. 1600miles on it. Sometimes it says it is connected when I don't have a trailer, other times it will say its disconnected when I don't have a trailer hooked up. If it matters, I've hauled some trailers but never anything with trailer brakes.
Kinda weird? Anyone also notice the trany gear display doesnt show 5-4 down shifts? Everyother gear light shows up, just not on the 5-4 downshifts...
Silly thing, the trucks still amazing.
  #6 (permalink)
Old 01-13-2012, 11:58 PM
2011 Ford F-350
I tried mine on my way home from work, it just displayed the current setting. I can only get the Trailer Disconnected prompt on the 2nd Gauge screen. I think we have different displays though since fg250's truck is (I believe) an XL.
Did it give you the option to OK out of it or is just up on the screen and you can't do anything with it?
__________________
Matt
  #7 (permalink)
Old 01-14-2012, 06:00 AM
snelldawg's Avatar
snelldawg snelldawg is offline
2012 Ford F-350
snelldawg is starting off with a positive reputation.
Happened on mine too once and awhile until I opened and closed the trailer power connection a couple of times to make sure it was really closed. Hasn't happened since.
__________________
2012 F350 XLT 6.2L CC LB FX4: Line-x, Bilstein 5100 shocks and stabilizer, OEM 20" wheels, Recon smoked cab and mirror lights
2005 F250 CC King Ranch (Gone but not forgotten)
"It's better to have too much and not need it than not have enough"
  #8 (permalink)
Old 01-14-2012, 06:33 AM
fg250's Avatar
2012 Ford F-250
It is an XL, it doesn't give you an option to close that warning on mine. although I didn't try to scroll to a different screen. I did a system check after the message went away and it said the brake controller gain was at 10 and it said trailer disconnected.
  #9 (permalink)
Old 01-14-2012, 06:35 AM
fg250's Avatar
2012 Ford F-250
Quote:
interesting, I'll have to check that out.
  #10 (permalink)
Old 01-14-2012, 09:21 AM
I've got the same readings as FG250, we both have XL's (mines a F350) and our dash's are laid out the same. I'll have to experiment with the door for the trailer power connection. Maybe all I need to do is open and shut it a few times?
  #11 (permalink)
Old 01-14-2012, 10:40 AM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
Try cleaning the trailer plug. Maybe there is something there or corroded shorting it out making the truck think it's plugged in then unplugged.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #12 (permalink)
Old 01-14-2012, 12:47 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to beholdRV_Tech is a splendid one to behold
Quote:
Agree, suspect your controller is reading resistance of a circuit as it would if trailer magnets were online.
Steve
__________________
RVDA/RVIA Master Certified RV Technician
You think you're confused?
2002 F350 Dually, Rhino Liner, Edge Evolution (running in stock mode), 4" exhaust, 6.0 cooler
2010 F150 super cab, box stock, bed slide, ARE bed cover
  #13 (permalink)
Old 01-14-2012, 01:36 PM
fg250's Avatar
2012 Ford F-250
Quote:
Steve
yes, it was very snowy and I'm starting to think that it had water/snow in the plug maybe?
  #14 (permalink)
Old 01-22-2012, 04:45 PM
jmiley jmiley is offline
2012 Ford F-250
jmiley is starting off with a positive reputation.
Quote:
I have a 2012 F250 4WD Lariat and I get the same message quite often, at least once a week and sometimes several times in one day, I am going to call the dealer to see what is going on, the truck is only a couple of months old and has 5,600 miles on it, the plug is clean.
  #15 (permalink)
Old 01-22-2012, 04:52 PM
fg250's Avatar
2012 Ford F-250
Quote:
please keep us posted
Tags
2008, 2011, 2012, 50, connected, disconnected, disconnecting, f150, f250, f350, ford, ford250, message, trailer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
