6.2L V8 Discuss the 6.2L V8
TRAILER DICONNECTED
Old 01-13-2012, 03:28 PM
fg250's Avatar
fg250
fg250 is offline
TRAILER DICONNECTED
I started my truck this morning after leaving the store and I got the trailer disconnected message for a minute or less, then it went away....anyone seen this?
Old 01-13-2012, 04:51 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
That's weird, did you accidentally bump the trailer brake controller? I can't recall what happens when you hit that with no trailer attached but I know something pops up on the screen...
Old 01-13-2012, 08:15 PM
fg250's Avatar
fg250
fg250 is offline
I don't think so, I think it's too far away for me to have done that. I have a friend of mine with an '09 chevy that was doing the same thing, and wound up having something replaced. I've driven it a few more times this evening and it hasn't done it since.?
Old 01-13-2012, 09:43 PM
nmhs's Avatar
nmhs
nmhs is offline
Mine just did that this morning when my passenger door was opened. Its a 2012 F250 crew cab.
Old 01-13-2012, 11:13 PM
Fawcett's Avatar
Fawcett
Fawcett is offline
Mine is doing it also. 1600miles on it. Sometimes it says it is connected when I don't have a trailer, other times it will say its disconnected when I don't have a trailer hooked up. If it matters, I've hauled some trailers but never anything with trailer brakes.
Kinda weird? Anyone also notice the trany gear display doesnt show 5-4 down shifts? Everyother gear light shows up, just not on the 5-4 downshifts...
Silly thing, the trucks still amazing.
Old 01-13-2012, 11:58 PM
2000silverbullet
I tried mine on my way home from work, it just displayed the current setting. I can only get the Trailer Disconnected prompt on the 2nd Gauge screen. I think we have different displays though since fg250's truck is (I believe) an XL.
Did it give you the option to OK out of it or is just up on the screen and you can't do anything with it?
Old 01-14-2012, 06:00 AM
snelldawg's Avatar
snelldawg
snelldawg is offline
Happened on mine too once and awhile until I opened and closed the trailer power connection a couple of times to make sure it was really closed. Hasn't happened since.
Old 01-14-2012, 06:33 AM
fg250's Avatar
fg250
fg250 is offline
It is an XL, it doesn't give you an option to close that warning on mine. although I didn't try to scroll to a different screen. I did a system check after the message went away and it said the brake controller gain was at 10 and it said trailer disconnected.
Old 01-14-2012, 06:35 AM
fg250's Avatar
fg250
fg250 is offline
interesting, I'll have to check that out.
Old 01-14-2012, 09:21 AM
Fawcett's Avatar
Fawcett
Fawcett is offline
I've got the same readings as FG250, we both have XL's (mines a F350) and our dash's are laid out the same. I'll have to experiment with the door for the trailer power connection. Maybe all I need to do is open and shut it a few times?
Old 01-14-2012, 10:40 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Try cleaning the trailer plug. Maybe there is something there or corroded shorting it out making the truck think it's plugged in then unplugged.
Old 01-14-2012, 12:47 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Agree, suspect your controller is reading resistance of a circuit as it would if trailer magnets were online.
Steve
Old 01-14-2012, 01:36 PM
fg250's Avatar
fg250
fg250 is offline
Steve
yes, it was very snowy and I'm starting to think that it had water/snow in the plug maybe?
Old 01-22-2012, 04:45 PM
jmiley's Avatar
jmiley
jmiley is offline
I have a 2012 F250 4WD Lariat and I get the same message quite often, at least once a week and sometimes several times in one day, I am going to call the dealer to see what is going on, the truck is only a couple of months old and has 5,600 miles on it, the plug is clean.
Old 01-22-2012, 04:52 PM
fg250's Avatar
fg250
fg250 is offline
please keep us posted
Quick Reply: TRAILER DICONNECTED
