1980 F-150 washer pump
Old 12-04-2010, 10:45 AM
1980302windsor's Avatar
1980302windsor
1980302windsor is offline
The windshield washer fluid pump seems to turn on (i hear the humming when i depress the button) but just a trickle of fluid escapes. I am thinking it is the pump (More Information for ANCO 6201)
Does this pump power both fluid nozzles or do i need 2 seperate pumps? Thanks!
Old 12-04-2010, 01:11 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
The one pump powers both nozzels. (Actually one nozzel with two jets)
The problem is most likely the nozzel itself. It gets plugged up VERY easily. I've replaced mine 5 times untill I thought to change the hose from the washer pump to the nozzel as the rubber hose was deteriorating on the inside and causing the nozzel to plug up.
Old 01-18-2012, 01:36 PM
300/6 Freak's Avatar
300/6 Freak
300/6 Freak is offline
oh thats a good idea! replace that hose! yup thats next on my list! that and figure out why not washer fluid! hardly worked yesterday and not at all today. No sound from the pump when i push the button so I need to check for voltage at the tank and go from there. Thanks for hte good idea to replace that hose though too!
mweaver644
01-25-2014 11:20 PM
Big Sky
03-17-2010 07:52 PM
waldrop1965
1983 - 2012 Ranger & B-Series
13
08-19-2005 01:56 PM
1081
04-11-2005 02:28 AM
Matts66
08-11-2003 10:11 AM
Quick Reply: 1980 F-150 washer pump
