ZF 6 Speed stuck in 1st. - Ford Truck Enthusiasts Forums
Old 01-13-2012, 12:00 PM
Journeymaaann Journeymaaann is offline
Journeymaaann is gaining momentum as a positive member of FTE.
Smile ZF 6 Speed stuck in 1st.
While driving home my transmission would not shift out of 1st gear. The clutch seems to operate normally when I come to a stop. Brake master & Clutch reservoirs are full. With motor off shifter seems to go into low or reverse but when started with shifter in that position the truck will stall if I let the clutch pedal all the way up. The shifter when left alone goes to the center of the pattern which should be neutral but when the clutch engages, it is in 1st. There doesn't appear to be any fluid leaks & the truck has 115K.
What do you think?
I like to take any opportunity to thank you guys who have given so much to me and so many others. I love reading the things you write & have really enjoyed learning about my truck.
Old 01-13-2012, 12:33 PM
Smokiesman's Avatar
Smokiesman Smokiesman is offline
Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.
I am no expert but I would say something has let loose ! There are a lot of parts that could fail and gum up the works!! Think yer gonna have to take it to the shop!!
Smokie
Old 01-13-2012, 12:37 PM
4inchlovin's Avatar
4inchlovin 4inchlovin is offline
4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of
never herd of this but did you remove the boot inside the cab on the shifter and give a look see. Im pretty sure you can remove where the shifter goes into the tranny from inside the truck and have a look see also
Old 01-13-2012, 01:27 PM
meier63's Avatar
meier63 meier63 is offline
meier63 is gaining momentum as a positive member of FTE.
I have a zf6 and while it is true that you can in fact remove the shifter boot from inside the cab, I dont think it's gonna give you any help in determining what your problem is.
There is a shifter lever cover on top of the tranny which you'll see with the boot removed, but I cant tell you what you'll see if you remove as I had no reason to remove it while replacing my clutch. Maybe someone else can chime in and let us know if there is any serviceable parts there.
Please keep us informed on your discoveries as I for one have 201,000 miles on mine and like to keep up on possible problems! Bill
Old 01-13-2012, 01:40 PM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Have you checked the tranny fluid level? When is the last time you changed fluid? I would at least check the fluid level. My 6sp. started getting a little stiff in first gear once and I change fluid and it helped.
Old 01-13-2012, 02:15 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is online now
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
Sounds like a sheared roll pin in the shifter assy.
Old 01-13-2012, 02:36 PM
levimorris85's Avatar
levimorris85 levimorris85 is online now
levimorris85 is starting off with a positive reputation.
Forgive me if I am way out in left field on this but it sounds like when you put it in low or reverse the truck is actually in 2 gears. Try going into first since that is the gear it is hung in and then straight down into N and see if that works. Our old dodge use to be bad about not coming out of 5th but the shifter would be in N and that is how we fixed it. If you jumped the sift opening all together the only way to fix it is pull the stick and use a short bar and pull it out of 1st back into N, put the stick back in and away you go. Good luck.
Old 01-13-2012, 04:47 PM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
Quote:
sounds about right to me
that would make it do what levi said. stuck in two gears at once
Barney
Old 01-13-2012, 05:49 PM
Thanks for your replies, I have read the thread about the roll pin in the shifter assembly. I got the boot off but didn't get the top of the transmission off yet. I'll take a look at that tomorrow & let you know. Thanks again.
Transmission or 4x4 please help Chzbrgrkid 1997 - 2003 F150 1 02-19-2017 03:39 PM
1981 F100 4 on the floor help NewbyRestorer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 08-14-2016 01:14 AM
Tranny problem...no 1st or 2nd. HMB_Superduty 1999 - 2003 7.3L Power Stroke Diesel 2 07-27-2015 01:10 PM
'86 F250 6.9L 4spd manual - Repeated Clutch Problems Caleb Petersen 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 12-25-2012 06:48 PM
installed new clutch etc - now won't shift gears. donberry 1987 - 1996 F150 & Larger F-Series Trucks 1 11-06-2011 03:55 AM
Tags
1999, 1st, assemby, econoline, f550, ford, gears, issues, removing, shift, shifter, speed, stick, stuck, zf, zf6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
