f350 4wd conversion - Page 2 - Ford Truck Enthusiasts Forums
f350 4wd conversion
Old 01-18-2012, 08:02 PM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
Ok guys, what about opinions of a ttb d50 conversion ? NO wheelin, muddin or playing, 4x4 just for 6 wheel traction in snow an loose ground
Old 01-18-2012, 08:16 PM
UNTAMND's Avatar
UNTAMND UNTAMND is online now
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Other than alignment issues ( which I never had) the d50 ttb is a strong axle.
I've been extremely impressed with mine. I've broken the tube on drivers side, but after a piece of 3/8 plate formed around the knuckle and pumpkin I doubt it will ever break again.
I snapped that a mile down a lake road, in a blizzard with a v-plow on the front and chains all way around and a yard of sand in back. I dumped the plow and (no kidding) drove the truck probably a little over 1/4 mile do my other truck and trailer could get to it.
Let's just say my most badass truck has a ttb d50 and I'm not scared one bit that it will let me down. Go to my YouTube account and see how bad I thrash my mud truck with a ttb d50. Like I said, other than alignment issues it's a great axle.
Old 01-18-2012, 08:37 PM
I like the ride of my 250 wayyyy more then my toy 350. But the coils on the dually are nice, wife wants the smooth ride of the coils
Old 01-18-2012, 09:01 PM
UNTAMND's Avatar
So keep the coils. I don't see why you can't.
Vans have coils on their 4x4 conversions. Just need to attach the coil buckets on the axle.
To get the height you want you either get longer coils (probably tricky to find 1ton rated lift coils maybe 2wd 1ton lift?) or drop the coil hoops lower on frame.
Old 01-18-2012, 09:03 PM
I dont need it lifted
Old 01-18-2012, 09:17 PM
UNTAMND's Avatar
Quote:
Not what I ment.
The 2wd coils may not lift the frame off the axle enough and the pumpkin may hit the crossmember or engine parts. The 2wd ttb beams are designed to take up less space so the big axle may need adjustment. So either get lift coils or drop the hoops til you get height you want.
Bumpstops are your friend.
Old 01-18-2012, 09:41 PM
I see. I still have to go thru all the links from fsb, but its kinda a pia on a phone. An my sig doesnt show up when i post from phone
Old 01-19-2012, 12:54 AM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
I had a lot of good luck adding the D-50TTB onto mine. I plan to switch out for a D-60 later on for durability, but the 50 is available everywhere for next to nothing! Affordable swap!
Old 01-19-2012, 05:15 AM
I may be sendin ya messages when i do my 50
Old 01-19-2012, 12:16 PM
yamahabiker94 yamahabiker94 is offline
yamahabiker94 is starting off with a positive reputation.
Thanks for the advice and the links. Really helped out. Depending on what my donor truck has, i will probably ditch the coils. its a tight truck to start (built to tow our boat during the summer) so im not really worried about the comfort of the ride. All i need is a truck with good 6 wheel traction for working on the farm in the winters (and the occasional mud hole of course haha). Donor trucks im looking at in the area are an '87 F250 with IFS and a 460 or a '89 F350 with a 7.3 naturally aspired diesel and the straight axel.
Old 01-19-2012, 12:49 PM
Dually: I am around!
Yamahabiker94: I went with leaf springs for durability and ruggedness. Coils are great, but when you plant a heavy load in the bed, and start traversing some farm land (dirt roads, pot holes, bar ditches) you can feel that the extra beef may be desired. For the same reasons as you have, is why I did mine. My CC Dually sucked on wet grass on a flat surface, and I do a ton of hauling and work with it, so I did not need a Wyoming winter creeping up and sinking the truck for the season!
Old 01-20-2012, 11:54 AM
Yeah I have the same reasoning for it. that and i work on a local ranch so all wheel traction is a must have in the winter. Our winters get rather nasty over here in nor cal. Infact we're expecting a nasty little snow storm tonight.
  #28
Old 01-20-2012, 12:14 PM
Well, I would also suggest grabbing up on that F-350 solid axle (D-60).. You will appreciate it a whole more!!!!
4wd conversion mxer0022 1967 - 1972 F-100 & Larger F-Series Trucks 53 04-25-2015 01:39 PM
2wd to 4wd conversion Acron1920 1987 - 1996 F150 & Larger F-Series Trucks 53 05-30-2014 09:00 PM
This topic seems to come up frequently so here's a link...2wd to 4wd conversion jtrux 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-28-2014 01:10 PM
4x4 conversion for 62 f-100 longbed 2wd praisethelowered17 1961 - 1966 F-100 & Larger F-Series Trucks 14 05-04-2012 06:01 PM
4wd Conversion for 1994 F350 dlp38910 1987 - 1996 F150 & Larger F-Series Trucks 3 04-29-2012 09:33 AM
Tags
1987, 1994, 350, 4wd, 97, conversion, excursion, f350, ford, kit, link, oklahoma, pot, truck, wd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
