1951 F1 V8 Oil Pan Question
Hello everyone,
I just took the oil pan off of my 51 Flathead V8 and was cleaning up the pan and had a question. The front and rear of the pan have some kind of a seal that is seized in place and dont want to budge. Are these seals just sitting in place and are stuck or is there a groove or something they fit into? I looked at the diagram on vanpelts but it doesnt shiow that much detail.
Also, while the flywheel is off is there a rear main seal or anything I should replace while the flywheel is off?
Thanks, Dave
Thanks, Dave
Flathead info here: Ford Flathead V8 .. 1932 thru 1953 • Index page
They use rope seals - in halves - in a groove in both the oil pan and above the crank. Only way to replace the top half is to loosen the crank. Front and back.
Installing the new one - pre-soak in motor oil, tamp in tightly and cut so it protrudes from the surface a bit (1/8") That way it will compress to seal.
Unless you're getting significant leakage from them, I'd let well enough alone.
DrZoom
08-19-2015 01:42 PM
