3.73 LSD question - Page 3 - Ford Truck Enthusiasts Forums
3.73 LSD question
  #31
Old 01-14-2012, 10:34 AM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by meborder View Post
good call on the true trac, that would be my choice as well.
the only thing i worry about with the way the true trac works is on ice. without the 1wsp kicking in, i'm not sure it would bias enough torque to move the truck.
the true trac can only bias torque as a multiple of the wheel that is slipping .... zero resistance, zero torque bias. this is why your rock crawlers dont use them. the only way to make them work with one wheel in the air is to use the foot brake. ... i bet on ice though, the parking brake could be used to make it more effecive.
like you said, i'd like to see someone else do it first
So kind of like driving up a steep grade with an open diff, you click the parking brake down a few notches?
  #32
Old 01-14-2012, 12:56 PM
meborder's Avatar
meborder meborder is offline
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
Quote:
yeah, something like that.
true tracs, or any heilical type LS (torsen), bias torque through a set of gears which gives it a mechanical torque multiplying effect.
for the sake of arguement, let's use 4
so, if one wheel can sustain 50lb-ft of torque, but starts to slip, the internal gears will transfer torque to the other side and in doing so multiplies it by 4. so up to 200 lb-ft of torque can be transfered to the other side, until that one breaks lose too.
but on ice, you may only be able to sustain ... say ... 4 ft-lb of torque ... so there is only 8ft-lb available to the other side. may not be enough for forward momentum, and you just spin one tire.
click the parking brake down a few notces puts resistance to the wheel on ice, now say 20ft-lb. so there is 80ft-lb available to the other side, but there is a brake applied there too, so it turns out to be 80-20, or 60ft-lb available for forward movement .. that might get it done.
this works until you burn the brakes up.
when the 1wsc kicks in, you are only applying to the wheel spining, so that could work out very well overall.
to get moving on an icy hill, i could amost assure you would need some brake action to get the other side to have enough torque to move the vehicle ... but other than that, the gear type seem like the way to go.
rearend ladelld33 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-05-2016 12:14 PM
Locking axle vs limited slip? 95 Canoe Hauler 2009 - 2014 F150 20 11-15-2011 03:51 PM
does my truck have a LSD? '83f3fiddy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 03-04-2011 07:04 PM
Diff Oil/Friction Modifier? dwild 1997 - 2003 F150 6 09-22-2009 07:58 PM
4.10 or 4.56? Neal05 Clutch, Transmission, Differential, Axle & Transfer Case 6 01-06-2007 06:18 AM
Tags
150, 1wsc, 2012, aerostar, control, elrtronic, f150, locker, lsd, rearend, spin, track, trucks, true, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
