3.73 LSD question - Page 2 - Ford Truck Enthusiasts Forums
3.73 LSD question
Old 01-13-2012, 02:55 PM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
What I am guessing is they are afraid people will use the locker with the truck fully weighted down and tear up the differential in a turn.
Old 01-13-2012, 04:45 PM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
Quote:
Originally Posted by flixden View Post
So there basically is no clutch type LSD available except with HD payload, right? But it doesn't matter, I guess, since the new e-locker axles have the "1-wheel spin control" (= "electronic LSD").
Yeah, I wish that e-locker with "1-wheel spin control" would have been available for my 2012 HD payload F-150. Sounds like the best of both worlds.
1-wheel spin control (1WSC) is a standard feature included in the traction control system, regardless of the diff style.
the only difference from 09,10 to 11,12, is that in 09&10, disabling the TC also disables the 1WSC. In 11&12, the 1WSC remains active when the TC is disabled.
the e-locker, when engaged, just gives the 1WSC nothing to do. a true LSD just gives the 1WSC less to do. and open diff makes it earn its keep.
this is all in the owners manual under the Traction Control section, FWIW.
Old 01-13-2012, 05:11 PM
flixden flixden is offline
flixden has a good reputation on FTE.flixden has a good reputation on FTE.flixden has a good reputation on FTE.
Yeah, makes sense. What I am not sure about is what's the need of the clutch type LS axle when the 1WSC is there anyway? It is pretty much the same feature, right, just the implementation is different?
Do all F-150's have the traction control as standard feature? Edit: I think the answer to that one is "yes". Just found it in the 2012 Order Guide.
Old 01-13-2012, 06:28 PM
L454S's Avatar
L454S L454S is offline
L454S is starting off with a positive reputation.
Got 3.73 LSD on my 2011 3.7 XLT SCab. Was a $300 option.
Old 01-13-2012, 07:38 PM
Ford8502 Ford8502 is offline
Ford8502 is starting off with a positive reputation.
I'm guessing the LS would be able to sustain a long messy situation where the 1WSC is there for quick little bursts.
Old 01-13-2012, 08:32 PM
Quote:
Until you wear out the carbon disks of course!
Old 01-13-2012, 08:40 PM
meborder's Avatar
i think the logic is that the LSD will *prevent* wheel spin, whereas 1WSC will *stop* wheel spin.
both have their limitations, LSD can only bias torque up to a certain point, 1WSC can only bias torque once there is wheel spin ... put the two together and you are biasing torque all the time.
I think that is why it is required with the HD tow package ... with 11k behind you, 4:1 first gear, 3.73:1 rear, diesel like low end torque, and a heavy foot, there could easily be enough torque to unload the right rear tire and cause it to spin. the LSD is always there and prevents wheel spin to the degree that the NVH engineers will allow. after that the 1WSC will use the brakes to bias more torque to the left rear.
at least that's my take on it.
Old 01-13-2012, 08:44 PM
meborder's Avatar
Quote:
nice truck
keep us all posted on how you like the 3.7 ... not many reports on here from 3.7 owners.
Old 01-13-2012, 08:51 PM
nice truck
I was wondering this myself. Would it tow my 13ft camper? My old 88 F250 with a 5.0 towed it but reallllyyyyy slowly.
Old 01-13-2012, 08:53 PM
Quote:
They make 13ft campers? Does that have an axle and wheels?
Old 01-13-2012, 09:02 PM
meborder's Avatar
my pop-up is 12 feet
weighs about 1400 lbs dry..... i could *almost* pull that with my escort
the 3.7 has about a 5k lbs tow rating .... should be plenty to pull just about anything that most reasonable people own.
even my boat, 19 ft fiberglass I/O only weighs about 3300 lbs. my exploder seems to do fine with that even. gets poopy mileage while pulling it, but pulls all but the biggest hills without dropping any speed.
strictly speaking, the 3.7 makes more HP and TQ than my 5.0 exploder .... should prove to be plenty of truck for most people, i would think.
Old 01-14-2012, 03:27 AM
L454S's Avatar
So far I have only made a couple fishing trips, but the boat launch is 100mi away. Can't tell my rig is even behind me. It's only a 16 x 48 Tracker Grizzly( maybe 1500#). Shows 19mpg at 65mph.
Just for comparison, my 05 Colorado CC I5 got 19mpg towing this rig. My 08Frontier V6 got 18mpg towing this rig. When you do 200+ miles a trip, you can gauge mileage pretty well.
  #28
Old 01-14-2012, 06:32 AM
NASSTY's Avatar
NASSTY NASSTY is offline
NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.
Because the 1WSC only works in some situations. I've done the same experiment as the guy in the video does and yes the 1WSC worked and acted like a LS going in a straight line on dirt like he did. But I have found other situations where it acts like an open diff giving you the 1 wheel peel.
When I am taking off from a stop sign, making a right hand turn if I take off spiritedly to get out into traffic I get the 1 wheel peel and it is difficult to get moving. Also the other day my driveway was icey. I pulled into my driveway and got out to get the mail. When I got back in the truck I got the 1 wheel peel and the truck wouldn't move. So I put it in 4x4 and it moved no problem.IMO the e-locker would be good for someone who does some serious offroading or deals with slippery boat launches or prefers open diffs. But I can't think of anything else it's good for. I just hate how the diff is open while your making a turn.
Eventually I'm going to swap out my e-locker for a Detroit (Eaton) TrueTrac LS (no clutches). I'm kind of waiting for someone else to be the guinea pig to see if disableing the e-locker messes with any other electronics. There's a few on another F150 forum that hate it too so I'm hoping one of them make the swap to see how it works for them.
  #29
Old 01-14-2012, 09:55 AM
That's good info, thanks!
  #30
Old 01-14-2012, 10:33 AM
meborder's Avatar
good call on the true trac, that would be my choice as well.
the only thing i worry about with the way the true trac works is on ice. without the 1wsp kicking in, i'm not sure it would bias enough torque to move the truck.
the true trac can only bias torque as a multiple of the wheel that is slipping .... zero resistance, zero torque bias. this is why your rock crawlers dont use them. the only way to make them work with one wheel in the air is to use the foot brake. ... i bet on ice though, the parking brake could be used to make it more effecive.
like you said, i'd like to see someone else do it first
8.8 rear end from an explorer to and f150 Pearlwhite94 1987 - 1996 F150 & Larger F-Series Trucks 9 01-09-2015 04:53 PM
What axels in my F250? 03-6.0 1999 to 2016 Super Duty 7 09-05-2014 09:50 AM
Surgery is Scheduled... LittleRadio 1968-2013 Full Size Vans 0 06-11-2014 09:40 AM
97 7.3 front & rear axle Salts Oil & Lubrication 5 05-15-2014 06:52 PM
Installing 2002 Super Duty Dana 60 and 10.25 Sterling Rear End Kudofo 1987 - 1996 F150 & Larger F-Series Trucks 6 12-20-2011 08:17 PM
Tags
150, 1wsc, 2012, aerostar, control, elrtronic, f150, locker, lsd, rearend, spin, track, trucks, true, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
