2003 F250 6.0 Problems
Old 01-12-2012, 09:08 PM
phlsimpson's Avatar
phlsimpson
phlsimpson is offline
I have a 2003 F250 6.0 that is currently having a couple of issues. First being that it idles around 1,000 rpm when in park all the time. Second being when in drive and stopped it idles all over the place. Tends to surge forward also. The idling issue is erratic. It tends to jump all over the place and almost sounds like it's going to stall. I pulled out the EGR valve and it was dirty. Cleaned and installed with no change. Any suggestions? Thanks in advance.
Old 01-12-2012, 09:10 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L Power Stroke Diesel forum.
Old 01-12-2012, 09:18 PM
wulfman's Avatar
wulfman
wulfman is offline
Well first off need to have it scaned for codes , there can be codes with out a check engine light on. Next the surging most likely ICP sensor located behind the turbo.
Old 01-12-2012, 09:20 PM
wulfman's Avatar
wulfman
wulfman is offline
OH and almost forgot welcome to FTE you will find a lot of helpful people here .
Old 01-12-2012, 09:28 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Im with David
unplug the ICP sensor start the truck and see if problem persists
if not you just found the Culprit
phlsimpson's Avatar
phlsimpson
Thanks. I scanned and got insufficent exhaust gas flow. That's when I cleaned the EGR valve with no change. I almost forgot to mention that I'm having issues with the tranny. lol. It shift hard when down shifting from 2nd to first when I'm coming to a stop. The high idling went away after the first EGR valve cleaning but after the 4th it just doesn't make a difference anymor. I think it might be time to buy a new valve. Would that also cause the idle to fluctuate irradically also?
Old 01-12-2012, 10:10 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
shure egr valve could cause similair symtoms
Old 01-13-2012, 10:59 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
Sounds like ICP sensor. I'm replacing the one in my dad's '03 this weekend for the same symptoms.
Old 01-13-2012, 08:28 PM
phlsimpson's Avatar
phlsimpson
Thanks guys. So it is possible for the ICP sensor to cause this without throwing a code? I started tearing into it and this is a beotch. Getting ready to put the new one in. Is it possible to just rig your current EGR valve as a delete but leave the cooler in? What would be the pros and cons to this?
Old 01-13-2012, 08:42 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
If you want a EGR deleate its best to get a kit
Unplugging the EGR valve just causes other problems
Old 01-13-2012, 08:44 PM
phlsimpson's Avatar
phlsimpson
I've been looking at a couple. What's the best out there for the money?
Old 01-13-2012, 09:01 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
or if you can Tig weld then weld caps on both ends of the egr cooler they have to be Good welds though or they will crack with the Hot/cold cycles
I went with a Full egr deleate a Sinister
6.0 Upgraded EGR Cooler | MKM Customs 6.0L Ford Powerstroke EGR Delete Kit
They have cheaper knock off kits now that wernt advalible when I did it
If you look around you can get the same thing for like 150.00
Old 01-14-2012, 12:46 PM
phlsimpson's Avatar
phlsimpson
So, they gave me the wrong ICP sensor. What would be the damage of driving around with it disconnected?
Old 01-14-2012, 05:31 PM
bismic's Avatar
bismic
bismic is online now
Received 2,489 Likes on 1,726 Posts
I wouldn't do it - I would think that you are going to have poor combustion by doing so.
Old 01-14-2012, 05:34 PM
bismic's Avatar
bismic
How do you know it is the wrong sensor?
ran5e
02-08-2012 03:56 PM
jmh5631
11-08-2011 09:23 PM
gun man 1
03-13-2011 09:13 PM
Superduty17
1999 to 2016 Super Duty
08-17-2010 02:05 AM
sgoodman
05-05-2004 11:30 AM
Quick Reply: 2003 F250 6.0 Problems
