Wont stay running, like , what. You finished the task and started it but it wont stay running? Have you been able to drive at all? And how long did it run?
thanks for your time it is an 2005 i finished the task put a new oil engine cooler because there was sludge that went through thoe whole cooling system have not been able to drive it. it runs for a few seconds and then dies
What exactly was changed , besides the oil cooler? What Told you the oil cooler was needing to be changed, did you do the work yourself? As you can see the more info you give the more we can help
If the oil cooler failed,the motor has to be completely flushed to get all the oil out of the cooling system, it is a very tedious task , if not flushed properly the "sludge" will clog the new oil cooler in very short order. So I assume the oil has been changed and is clean, the filters are motorcraft and new?
It sounds like you had chocolate milk looking coolant... right? If that's the case you need to really clean out the whole system and if that wasn't done, or even if it was, a few sensors like the IPR Blade mentioned could be shot. You might need a second oil cooler too.
