Engine block codes. - Ford Truck Enthusiasts Forums
Engine block codes.
Old 01-12-2012, 01:00 AM
Beav93 Beav93 is offline
Beav93 is starting off with a positive reputation.
Engine block codes.
ok so i have a 1978 F150 which i was TOLD had a 351m in it.. but further research of the block code located above the starter is saying i have a 400. so. i dont know what to buy parts for.. the code is D1AE 6015 AO. help?????? anyone please.
Old 01-12-2012, 01:04 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Block for the 351M is the same as for a 400. The only difference between the two is the stroke. That's also the only way to tell the difference between them, measure the stroke.
Old 01-12-2012, 10:56 AM
Correction. AC as last two letters of the block code. and i read the casting numbers for the m blocks started with D7TE not sure if thats true or not. so how would i measure the stroke??? what would the difference in the two be? thanks for all advice. it is GREATLY needed
Old 01-12-2012, 11:40 AM
also. found out that my particular truck came off the factory line with a 400 c.i 6.6 liter engine. but im still not sure if thats the original engine.
Old 01-12-2012, 01:27 PM
mikeo0o0o0's Avatar
Quote:
Bring engine to TDC #1 and pull the spark plug. Stick a long dowel or rod through the spark plug hole untill it bottoms against the piston and mark the rod. Rotate the engine on half turn and insert the rod again and mark it. Measure the difference between the marks, that's your stroke.
3.50"=351, 3.98"=400.
Old 01-12-2012, 02:40 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
I have a 1978 F150 which I was TOLD had a 351m in it.. but further research of the block code located above the starter is saying i have a 400.
So. I dont know what to buy parts for. The code is D1AE 6015 AC.
Engine's been swapped, not an uncommon occurrence on a vehicle this old.
D7TE-6015-AB, -A1B, -A2B = Block casting numbers for 1977/79 F100/350 & 1978/79 Bronco with 351M/400 engines.
D1AE-6015-AC = Block casting number for 1971/74 Passenger Cars with 400 engines.
The engine code is the 4th digit of the VIN
1977/79 F100/350: B = 300 I-6 / G = 302 (F100/150 only) / H = 351M / J = 460 / S = 400.
351M/400 not offered for F100/350's prior to 1977, nor for Bronco's prior to 1978 / 400 introduced in 1971 Passenger Cars / 351M in 1975 Passenger Cars.
Old 01-12-2012, 11:47 PM
Ok so now that I know what I have I am in need of a plate that goes between the engine and bellhousing . I am eating up my starter and flywheel when I try to crank it. Has 180 tooth flywheel. Got a plate on it but its for a automatic tranny. Mine is a four speed had to cut where the starter goes to make it work. So I'm not exactly sure what the problem is. Could you guys help with this? Suggestions???
Old 01-13-2012, 01:51 AM
I have searched all over the internet for a motor plate and cant seem to find one
Old 01-13-2012, 08:28 AM
robbie42301's Avatar
robbie42301 robbie42301 is offline
robbie42301 is starting off with a positive reputation.
If the flywheel has been worn down even a little bit, it may cause even a new starter or drive gear to shear as well. I ran into this problem myself and had to change the flywheel. After changing the flywheel and adding a new starter gear everything works fine. As for any difference between the plate between the trans and motor, I'm not sure. But I would inspect the flywheel all the way around (if you haven't already) before buying anymore parts. Just a thought, good luck.
Old 01-13-2012, 10:28 AM
Well i bought a new ring gear for the flywheel and drive gear for the starter about a month ago and had the ring gear pressed on and the drive gear put in my starter and it still grinds.also this is not the original starter. Before I got the truck it had a auto zone remanufactured one on it. Could this be part of the problem?
Old 01-14-2012, 12:40 AM
I have started a new thread on the starter topic. Its under starter and flywheel problem, if anyone could help
Old 01-14-2012, 08:56 PM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
You will need the manual flywheel and starter. I don't know a lot about it but this will bump this thread s others will see it.
Old 01-14-2012, 09:18 PM
JB78f150's Avatar
Didn't see your other thread glad you got it figured out.
need help with codes danglin 1999 - 2003 7.3L Power Stroke Diesel 18 11-01-2012 10:49 AM
V/F Code spring swap do I need blocks in rear? PBG928 Excursion - King of SUVs 52 06-07-2012 10:41 AM
x-code/c-code question - I gotta be different jeeplj8 Excursion - King of SUVs 33 03-23-2012 11:52 AM
Special Order or Package Codes Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 12-28-2011 01:02 PM
lift gain after Excursion spring swap the ponz Excursion - King of SUVs 5 05-04-2011 05:56 PM
Tags
1977, 197779, 1994, big, block, bronco, casting, code, codes, d7tea2b, d7teab, diae6015ac, engine, ford, plate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
