Pulling, darting...all over the road
Having some problems with the brakes, when I hit the pedal the truck pulls hard to the drivers side. This has been getting worse the past couple weeks and I'm looking for things I should check. I read that these trucks are bad about the caliper guide pins sticking, but I can't imagine that would make it pull this bad. What else should I be checking? I already know the calipers aren't dragging.
Also just driving around, the truck randomly pulls left or right, and then will drive straight. I know the 35's will follow the road more than the old 33's, but it still seems like its wandering too much. I'm sure I need a new steering stabilizer at 265xxx miles, but what else should I look at? Already verified that the balljoints and unit bearings are good, the tires have no play side to side or up and down. Thanks.
Some clarity would help to move this forward tho.
Looking back I really could have worded that better, but yes, I mean that whenever I use the brakes it pulls hard to the drivers side.
You'd be surprised what those pins are capable of causing. It costs nothing but time to grease them. A new stabilizer would probably help as well, running larger tires with one that's shot can cause some unwanted feedback from the road...
Primetime1
09-17-2018 08:48 AM
80FlareSide
17
06-24-2012 02:26 PM
Bullride_101
10-29-2006 05:23 PM
stretch5881
11-08-2005 05:16 PM
