CODE P0488 with aftermarket intake elbow installed - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-11-2012, 10:22 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM BROWN DOG KTM is offline
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
My Gear Box Z DPF-R programmer don't
Keep the wrench light out from P0488 DTC.
Anybody know what resistor to add to which of the
4 wires that plugged to the throttle flap motor thingy
In the stock intake (now removed) ??
Old 01-11-2012, 10:27 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
why would you remove a safty device that should help prevent a possible runaway engine on that is know to overfill the crankcase and pump oil back in for reburn?
and sorry I dont know the awnser to the question
Old 01-12-2012, 06:09 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I think I would put that stock intake back on for now.
Old 01-12-2012, 07:37 AM
R-T0r21on R-T0r21on is offline
R-T0r21on is starting off with a positive reputation.
You need a tuner that disables the EGR function in order to use that elbow.
Old 01-12-2012, 10:05 AM
My Tuner does delete the egr valve, but not the throttle
Plate motor in the intake elbow that I removed.
I sent it back to Gear Box Z for them to re-program
It to delete the throttle control code P0488 with No
Success :-(
I'm gonna call them back ....
Old 01-13-2012, 10:42 AM
Quote:
For safety, peace of mind or legality ??
Old 01-13-2012, 10:47 AM
senix's Avatar
Quote:
For the code till you get it figured out.
Old 01-13-2012, 06:31 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
If u got the wrench your proably gonna end up with your truck going into limp mode after awhile, thats wat mine did tell i got the right spartan tunning im guessing ur cruise proably dosent work ither. Best to put it back tell u get the right tunning
Old 01-14-2012, 08:40 AM
Wrench light has been on for 1000 miles of so.
It runs fine so far ....
The cruise control works fine.
The Throttle Flap Motor that was in stock
Intake Elbow, only regulated "air flow" when the EGR
Valve was dumping Soot into the engine.
Gear Box Z is checking into a programming "fix" for me.
I just wish I knew what Ohm Resistor to put in the wiring harness
to satisfy the PCM that the throttle valve flap motor was plugged
up & working :-(
Old 02-17-2012, 08:55 PM
Wrench Light on with code P0488
I used two 1K 1 Watt Resistors from Radio Shack to Satisfy the PCM that
the Throttle Motor was plugged up & working
I put one resistor between #1 black wire & #3 blue wires.
I put other resistor between the #2 green/white wire & #4 green wires.
Old 10-23-2012, 01:02 PM
ithaca1230 ithaca1230 is offline
ithaca1230 has a very good reputation on FTE.ithaca1230 has a very good reputation on FTE.ithaca1230 has a very good reputation on FTE.
Any Idea if this would work on a 6L?
Old 10-26-2012, 08:17 AM
Quote:
It's possible, but I don't know for sure
Does the 6.0 have this throttle motor flap in the intake
Similar to the 6.4 setup ??
With 4 wires hooked to it ??
Old 10-26-2012, 01:53 PM
I never saw a 6.4 set up. The throttle body is between the intake manifold and the elbow. one side has a plug that goes to a motor that opens and closes the butterfly 3 wires and the otherside has a ?position sensor with 2 wires. I havent set up a way to download pictures yet I can try to do that this weekend. What set up does the 6.4 have?
Old 10-26-2012, 03:10 PM
The EGR Valve & air flap motor (don't kno proper name) is all in the the stock intake elbow assy on my 6.4L, that I removed & installed the billet alum Aftermarket unit
Old 10-26-2012, 03:49 PM
on the 6l the elbow and the egr valve throttle body whatever you call it are 2 different pieces.
P0488 Code After Intake Elbow Install Nitty62 6.0L Power Stroke Diesel 6 05-21-2016 11:27 AM
04 6.0 Egr Fail - Help Please! drolens 6.0L Power Stroke Diesel 0 04-13-2016 03:54 AM
No start. Video, codes and details. HALP! Jeff Watts 6.0L Power Stroke Diesel 9 02-13-2016 09:29 AM
6.4L Low Power- P0488 EGR Throttle Plate Codes makuloco2000 1999 to 2016 Super Duty 0 01-17-2014 08:06 AM
04 EGR TPS question fordf150guy 6.0L Power Stroke Diesel 4 11-24-2013 01:00 PM
Tags
1996, 64, air, codesp0488, elbo, elbow, f350, ford, forum, intake, kit, lift, markit, p0488, srw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
