6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Power Steering fluid leak common?
Old 05-14-2016, 06:07 PM
DieselCamper's Avatar
DieselCamper
DieselCamper is offline
I had my friend look at it and he said the steering gearbox might be corroded. Is this common? Is there any lines by there that may be common for leaking? It loses the whole reservoir of ATF in 3 days, which is strange
Old 05-30-2016, 07:55 AM
Ford_Doctor's Avatar
Ford_Doctor
Ford_Doctor is offline
Most power steering fluid leaks come from the lines or the pump in my experience but the occasional steering gear leak does pop up. Usually it's a seal. You would need to define corrosion and where it is on the steering gear to come to a conclusion.
Critterhunter
1983 - 2012 Ranger & B-Series
07-24-2020 10:25 AM
cardiacjohn
1999 to 2016 Super Duty
09-14-2013 12:55 PM
Kleenax
11-27-2009 08:37 PM
RUF150
05-30-2004 05:45 PM
Tattoo Matt
10-24-2003 04:56 PM
Quick Reply: Power Steering fluid leak common?
