CODE P0488 with aftermarket intake elbow installed - Page 3 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #31
Old 02-24-2014, 09:21 PM
Mud Doc's Avatar
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
GShretter,
"My EGR is disabled and capped but I can't remove the equipment because I will get engine lights and so forth no matter what plus I don't want to remove the emissions equipment due to changes coming to diesel emissions in Texas. Oh it's coming.. "
Can you elaborate on the diesel emissions changes in Texas?
Thanks,
Joe
  #32
Old 02-24-2014, 09:50 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM BROWN DOG KTM is offline
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by mikemass View Post
... When I said keep the sensors plugged in and zip tie them up, I was talking about the sensors on the exhaust ...
I bought the AFE exh pipe WITH Bungs.
My 3 exhaust sensors are threaded IN exh & plugged In.
  #33
Old 03-03-2014, 03:50 PM
Kimani Kimani is offline
Kimani is starting off with a positive reputation.
Dose anyone know if this combination of modifications will work together with out having codes poping up on my dash?
1.Spartan Phalanx Tuner
2.Sinister Complete EGR delete with Intake Elbow
3.S&B Cold Air Intake System with Wraps Filter
  #34
Old 03-03-2014, 07:31 PM
mich800 mich800 is offline
mich800 is starting off with a positive reputation.
Mich800 -- We are talking about 2 different things. When I said keep the sensors plugged in and zip tie them up, I was talking about the sensors on the exhaust system for the DPF delete... (another job altogether) Apologies, but now I realize you are talking about the sensors under the hood for the EGR delete. When I get a chance I will post some more pictures of all of those sensors and where they are now. (maybe a video and talk you through it). I might not get to it for a few days, so stay in touch with me, either through this thread or via PM.
I would like to note that there is tremendous information on these message boards regarding this job. Not just this this board, but the other Ford Diesel Forums as well. If it wasn't for the knowledge I gained on these boards, I would not have been able to do this job. Before I even turned the first wrench, I looked up every post on this topic and knew exactly what I was getting into. BrownDog was a huge help. check out some of our conversations.
And I will be back with those visuals when I get a chance.
I have everything back together. It looks like everything worked. One question on the DPF-R. What is the difference between the standard and economy tune? Is the standard the 70 HP tune?
  #35
Old 03-03-2014, 07:47 PM
mikemass's Avatar
mikemass mikemass is offline
mikemass is starting off with a positive reputation.
Quote:
No. The Econ tune is the 70 hp boost.
  #36
Old 03-03-2014, 08:15 PM
Thank you. I called but I think there was a language barrier when trying to get the answer.
  #37
Old 03-03-2014, 09:57 PM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
I didn't realize this was an issue; I know some guys bought new intake elbows, but is the stock one going to draw EGR gas even if the tune disables the EGR valve?
  #38
Old 03-05-2014, 04:23 PM
Did you guys just tie up the egt sensors raw to the elements or did you tape or bag them up somehow?
Also, did you also plug in the pressure sensor? and if you did what about the piece that was in the DPF?
  #39
Old 03-05-2014, 09:03 PM
mikemass's Avatar
Mich800. sorry, i still owe you some pictures. I didn't even tie them up. They just dangling loose under the hood. They don't get in the way of anything. I promise I will get to those pics this weekend. Easier if you see it.
  #40
Old 06-21-2014, 04:36 PM
giosysco giosysco is offline
giosysco is starting off with a positive reputation.
did you ever put up pics or vids
  #41
Old 06-21-2014, 04:50 PM
Quote:
Originally Posted by BROWN DOG KTM View Post
I used two 1K 1 Watt Resistors from Radio Shack to Satisfy the PCM that
the Throttle Motor was plugged up & working
I put one resistor between #1 black wire & #3 blue wires.
I put other resistor between the #2 green/white wire & #4 green wires.
have any pics
  #42
Old 06-21-2014, 09:16 PM
No i dont , sorry
  #43
Old 05-29-2016, 09:51 PM
Mr. VT365's Avatar
Mr. VT365 Mr. VT365 is offline
Mr. VT365 is starting off with a positive reputation.
not all 6.0's had an EGR throttle valve. only some until 2005 I remember correctly.
  #44
Old 05-30-2016, 08:15 PM
Idk about 6.0
We was referring to 6.4's in this thread lol
6.4 sputters once in awhile at idle 7.3stroker2 6.4L Power Stroke Diesel 0 01-10-2017 12:08 PM
P0488 Code After Intake Elbow Install Nitty62 6.0L Power Stroke Diesel 6 05-21-2016 11:27 AM
04 6.0 Egr Fail - Help Please! drolens 6.0L Power Stroke Diesel 0 04-13-2016 03:54 AM
No start. Video, codes and details. HALP! Jeff Watts 6.0L Power Stroke Diesel 9 02-13-2016 09:29 AM
6.4L Low Power- P0488 EGR Throttle Plate Codes makuloco2000 1999 to 2016 Super Duty 0 01-17-2014 08:06 AM
Tags
1996, 64, air, codesp0488, elbo, elbow, f350, ford, forum, intake, kit, lift, markit, p0488, srw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
