1990 f250 fuel filter - Ford Truck Enthusiasts Forums
Old 01-11-2012, 09:44 PM
countryshiz87 countryshiz87 is offline
countryshiz87 is starting off with a positive reputation.
Has anyone replaced the fuel filter on a 1990 f250? i need some help on how to go about doing it. Do i need the special tool required on newer fords?
Old 01-12-2012, 01:08 AM
deeznuts822's Avatar
deeznuts822 deeznuts822 is offline
deeznuts822 is starting off with a positive reputation.
Its not very hard, I use a small flathead screwdriver to remove the clips,Worse part is the fuel that leaks out when removing the lines.
Old 01-12-2012, 08:24 PM
cool thanks
Old 01-12-2012, 09:48 PM
Ole' gray's Avatar
Ole' gray Ole' gray is offline
Ole' gray is starting off with a positive reputation.
yup, i change mine every 5 months it seems, i need a new tank on my truck. Oh and watch for when the gas leaks into your eye. Burns like a mother. but its about the most simple fix i do on my truck
Old 01-13-2012, 01:46 AM
mgroshong mgroshong is offline
mgroshong is starting off with a positive reputation.
As said it takes about 5 min. very easy to do.
1990 F-25 won't stay running (Video) Michael Maddux 1987 - 1996 F150 & Larger F-Series Trucks 2 02-16-2016 09:55 PM
1990 F250 460 idle problem with video emspjay 1987 - 1996 F150 & Larger F-Series Trucks 106 12-30-2014 10:59 AM
302 in a 1990 f250 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 20 06-08-2014 12:05 PM
bell housing bolts 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 7 02-26-2014 11:50 PM
Engine doesn't want to start! 1990FordF250Diesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 08-31-2011 12:47 PM
Tags
1990, 1996, 250, 351, change, diesel, f250, filter, filters, fuel, gas, replace, start, takes, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
