Ford Dealer Changing Plugs!!!
As others mentioned, I usually use anti-seize on ANY threads going into aluminum.
However, it is rumored that the nickel plating (bright silver) on the newer Motorcraft plugs will not seize nearly as traumatically as the old black bodied plugs. So I installed those dry. I'll let you know how that worked out in a few years....
FYI, unless you were using a 2" long ratchet or are really weak, that is WAY too much and damaged the threads. Save your pennies for a Timesert kit.
Anyone who'd like to read more about the Ford heads should check out the blownsparkplugs.com site There is a lengthy article concerning torque, anti-seize and a few other eye-opening facts too---well worth the read.
