Pics of lifted 2wd? - Ford Truck Enthusiasts Forums
Pics of lifted 2wd?
Closed Thread
Old 01-11-2012, 05:31 PM
Shwan_89HD's Avatar
Shwan_89HD Shwan_89HD is offline
Shwan_89HD is starting off with a positive reputation.
Pics of lifted 2wd?
Hey yall im looking on lifting my 89 F250 2wd bout 6 inches, and i had so much trouble looking for a lift kit for my truck 2wd, all i could find was a 3 inch body lift. BUT luckily i found this awesome site that has a 6 inch skyjacker lift for 2wd! 80-96 Ford F250-F350 2WD 6" Skyjacker Lift Kit @Top Gun Customz Im not a hardcore mudder cause if i was i would have bought a 4wd, but im doing it mainly for looks and the feeling of riding high. I have some 36 in mickey thompson baja claws waiting in my garage until i get the lift cause they definately wont fit stock height im currently running 33s and they rub. If any of yall can share pics of your lifted 2wds and even 4wds. Thanks!
Old 01-11-2012, 08:12 PM
Nickk97tml's Avatar
Nickk97tml Nickk97tml is offline
Nickk97tml has a good reputation on FTE.Nickk97tml has a good reputation on FTE.
Old 01-11-2012, 09:32 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
This is my 89 4x4 F250, approximately 7-8 inches of lift in the front, and 5-6 in the rear. 35" BFG's in this picture.
Old 01-12-2012, 12:21 AM
AKFORD4x4 AKFORD4x4 is offline
AKFORD4x4 is starting off with a positive reputation.
Quote:
why have un-equall lift heights from front to back???
Old 01-12-2012, 12:26 AM
GNR22's Avatar
Quote:
The truck isn't level from the factory, so lifting the front more than the rear levels it out.
Old 01-12-2012, 12:27 AM
I was gonna say it looks level and good in the pic.
Old 01-12-2012, 12:29 AM
GNR22's Avatar
Well good, that's what i was shooting for. as it sits right now, measured at the top of the fender well, the front is a quarter inch shorter than the rear still, which is unnoticeable.
Old 01-12-2012, 12:38 AM
GNR22's Avatar
IMHO, i agree with you. You really can't wheel with a 2wd. OP said he could hardly find a lift kit for it. There is a reason for it, there's isn't a market for lifted 2wd trucks. I don't understand why people want to jack a truck up just for the look of it. you might as well invest in glue on hood scoops and flame decals. Glue on hood scoops, 10 horsepower, flame decals, 5 horsepower a piece
Last edited by Fomoko1; 01-13-2012 at 06:50 PM. Reason: Removing the offending quote
Old 01-12-2012, 12:54 AM
Hotshot869's Avatar
Hotshot869 Hotshot869 is offline
Hotshot869 is starting off with a positive reputation.
I can understand leveling out the front end of a 2wd, to make it look better, but jacking it up so and so inches and such is a bit over the top, 1-2 inches total lift, plus level kit i think looks decent. I've done some amazing things with my truck before it burned down, and it was 2wd..You just need to know how to distribute weight in the bed evenly.
Old 01-12-2012, 03:45 AM
Quote:
I agree with you BUT If I had a dollar for everytime I have heard "My 2wd will go just about anywhere a 4wd will go" Id be friggin rich. WRONG, you could do some "amazing things" FOR A 2WD truck. They do not compare to a 4wd. IF YOU EVER see a 2wd that can go anywhere near the places a 4wd truck can go then it has nothing to do with the truck and it has EVERYTHING to do with how SHATTY the driver of the 4wd is
I have seen complete idiots POUNDING the shiz out of their 2wd trucks trying to go where they should not be going using speed and momentum to get over and through things because with a 2wd thats their only chance, its stupid. Besides a 4wd truck IS A 2WD TRUCK until you decide to lock in the front hubs.
Old 01-12-2012, 03:55 AM
I should throw in a disclaimer. If you are comparing a 600 HP 2wd truck with paddle tires in the sand dunes of GLAMIS that weighs 2200 lbs versus a stock 302 powered 4wd F-150 with 200 hp that weighs 4500 lbs then yeah the 2wd is gonna spank the 4wd.
Old 01-12-2012, 07:17 AM
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
im not a fan of 2 wheel drive trucks but if he doesnt need 4x4 and just likes the looks of a 4x4 why waste money on a 4x4. and mileage should be better. show us your pics when you lift it.
Old 01-12-2012, 08:38 AM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
IF you want to look like a poser then I have to ask why??? (...)
Well, those of you with stock dana/sterling axles in your 4x4's are posers too.
Because real off-roaders use rockwells or custom fabricate a four-corner independent suspension with frame-mounted pumpkins.
So AkFord4x4, YOU POSER! (big grin)
Teasing aside, we all know the automotive world is full of different people. Some focus on function, some on form, some a mix. Some can 'only' tolerate having a big block feeding a set of oversized glasspacks. Others like to ride high, some like to ride low. Some like solid colors and some like zebra stripes. Some like chrome and others blacken everything out.
While you or I may not see the functional purpose in lifting a 2wd truck you and I can probably appreciate that a lifted truck does look cool if done right. To me, lifting a 2wd truck is a styling change - no different than installing cool mirrors or a Lund viser or a wicked bumper or whatever else we can think of.
Around where I am (northern NJ) I see an awful lot of garage kept, never seen a flake of snow, over-waxed "sissy trucks" - immaculate F350 crewcabs, sometimes dually and diesel too - yet they're used solely as commuter vehicles or grocery getters. Totally not the "right" vehicle for that purpose. But, if someone enjoys driving their F350 crewcab diesel dually to church every Sunday, who am I to pass judgment.
Old 01-12-2012, 08:53 AM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
I thought FTE was about advise, not insults
Old 01-12-2012, 09:05 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Haha.
I just see a lifted 2wd cherokee with 32-33s on it.
It was hilarious because on them it's the same setup as 4wd only without a pumpkin. So you could clearly see it was just a strait tube in front.
Funny funny.
Anyway. I kinda like the ford 2wd prerunner look.
Go for it. I just think these trucks look mean with minimal lift and knobby tires
Closed Thread
Whats in this Lift kit??? Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 12 06-07-2013 04:54 PM
6 inch lift for F150 on F250? Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 12 01-21-2013 09:37 PM
6 inch skyjacker lift! Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 6 08-28-2012 06:50 PM
Lifted 2wds??? Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 51 03-03-2012 11:39 AM
Lift kit Question For my 1982 F-250 2wd Black_Stallion 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 58 01-04-2010 01:09 AM
Tags
1988, 1989, 2wd, 6, 89, 93, coil, diesel, f150, f250, ford, inch, kit, lift, lifted, pics, spacers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
