6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 10-21-2014, 08:09 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Tire Pressure Sensor Fault
Old 01-11-2012, 01:24 AM
aquaman's Avatar
aquaman
aquaman is offline
I've been getting this warning intermittently for the past couple of days. 3 months ago, I got a false alarm for low tire pressure.
Is there a way to see which tire is complaining? Do I need to retrain the wheels? I rotated them 10K miles ago, but all 4 are at 75psi so there should not be any complaints.
Or is this something only the dealer can fix?
Old 01-11-2012, 07:13 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
To the best of my knowledge you cannot tell which one.
Perhaps a tire shop could tell?
Old 01-11-2012, 08:34 AM
Harley250SD's Avatar
Harley250SD
Harley250SD is offline
I'm running at 55 lbs a tire and just had the sensor light go one a few days ago as well and stay on. What is the proper pressure for normal driving? (without load)
Old 01-11-2012, 09:11 AM
senix's Avatar
senix
senix is online now
door cert label will have it..but mine says 65 psi.
keep in mind that is min...max will be on your tires.
Also the lower the pressure the more rolling resistance you have. Maybe a better ride but also less hauling capacity too.
Higher loads then you need to increase the air pressure.
I run all mine at 80 psi.
Old 01-11-2012, 03:50 PM
smcnulty's Avatar
smcnulty
smcnulty is offline
check the spear tire I had low pressure in the spear
and it set off the light
Old 01-11-2012, 06:06 PM
Tom's Avatar
Tom
Tom is online now
This doesn't sound right to me, as there is no TPMS sensor in a factory spare tire. Did someone swap a factory rim into your spare position?
Old 01-13-2012, 11:33 PM
aquaman's Avatar
aquaman
aquaman is offline
Got the truck back from the dealer. They scanned everything and no trouble or stored PIDS found. Weird since I thought there was some counter that stored how many miles since the last fault or something.
They reset my tire pressures back to 65psi in front and 80psi in the rear and then retrained the sensors. I had all 4 set at 75psi earlier.
What's not clear to me is why that would fix a "tire pressure sensor fault". If my tires were low or too high, it'd make more sense to say tire pressure 'low' or 'high' instead of 'fault'
I guess I'll keep an eye on this. I asked the service adviser what happens if I have the same problem after my 3/36 expires. It sounded like they'd still fix it at no charge since I complained about it already
BTW, I've been driving without my spare for a long time. No issues. It's sitting under my workbench in my garage. When my wife drives without her spare, her car is expecting the 5th sensor and complains accordingly.
Old 01-14-2012, 06:50 AM
senix's Avatar
senix
senix is online now
gotta ask...why no spare?
Old 01-14-2012, 10:34 PM
aquaman's Avatar
aquaman
aquaman is offline
It's 125-150 fewer pounds of mass I have spend fuel on accelerating around town :-) Probably doesn't make much difference in the truck, but for sure my wife says without her spare, she feels a big difference in her car, as if she got a few extra HP.
In the past 25yrs, I've yet to need my spare tire(s)...knocking on lots of wood. The few times I've had nails/screws in my tires, I just drove it like for a short distance until I could get it fixed. If I'm going on a cross-state trip, the spare goes back in.
Old 01-15-2012, 07:22 AM
senix's Avatar
senix
senix is online now
seems around here alot of peopl emply that spare tire removal. I usually drive by them on the side of the road waiting on a jack or on the cell phone.
Old 01-16-2012, 03:26 AM
Neil64's Avatar
Neil64
Neil64 is offline
Air Pressure
I keep 60 in front and 50-55 in the rear in my factory 20s with Goodyear Wrangler AT/S'. They seem to wearing OK and I rarely haul anything with any weight. When the snowplow goes on, the front go to 80psi and the rear to 65psi with a bed load of old wheels and tires for ballast. For you folks that run 65 or 85 psi empty, are your tires wearing evenly?
Old 01-16-2012, 05:15 AM
senix's Avatar
senix
senix is online now
Mine are at 80 and wear just fine.
Old 01-16-2012, 06:36 AM
slowmans's Avatar
slowmans
slowmans is offline
I know a lot of people don't, but you SHOULD keep your tires at max. I was told this by the gentleman who is a tire distributer and changes our tires on our fleet trucks at work. That being said I keep mine at 72 all around and max is 80.
Old 08-07-2013, 12:16 AM
Enviroguy's Avatar
Enviroguy
Enviroguy is offline
Lightbulb Tire Pressure Sensor Fault
Ok so I spent 6hrs at the dealership today trouble shooting my "Tire Pressure Sensor Fault" on my brand new F-250 Platinum Super Duty I spent way to much on. What we've come to conclude is, the module that receives or controls the receiver for the tire sensors, also controls the receiver for the remote keyless entry. It gets radio frequency interference or RFI from various apple products and motorola gadgets that may be plugged into any outlet in the truck (including the USB's in the dash) getting juice. Ford motor company only indicates that "some" electronic devices that are being charged in the vehicle "may" cause RF interference to the TPMS module. The dealership basically said, "don't charge anything in the vehicle" which leaves me wondering why the heck they even bothered putting outlets in the truck to begin with .
I've noticed that when my "Tire Pressure Sensor Fault" message comes on, my truck is nearly impossible to remote start/lock/unlock/panic unless I'm literally within a 12' radius of the truck. After unplugging my iPad, my key fob miraculously started working properly. I'm hoping to figure out how to shield the "module" in the passenger door frame/toe kick so that I can charge my phone, iPod, iPad, and cellular booster since my truck is my office.
So far, my plan is to line the cover panel with some foil and grounding it out, kind of like shielding an electric guitar pick up. If anyone else has any ideas, I'd really appreciate some serious input .
Thanks.
Old 08-07-2013, 03:05 PM
datsmoke's Avatar
datsmoke
datsmoke is offline
i dont know about that specific vehicle but some cars do have a tpms sensor in the spare tire
Quick Reply: Tire Pressure Sensor Fault
