Fuel opening to gas tank hose 76 F150
Anyone have any suggestions where to get a good quality hose that runs from the fuel-neck-opening to the rear gas tank. I usually get it from LMC truck, but they all dry rot and leak after and year or so (live in southern AZ). Royal pain dropping the gas tank just to install this hose every..year. Any other sourcing suggestions would be much appreciated.
<O</O
Thanks.
<O</O
Thanks.
Anyone have any suggestions where to get a good quality hose that runs from the fuel-neck-opening to the aft axle gas tank.
<O</O
Thanks.
<O</O
Thanks.
Styleside pickup w/aft axle fuel tank: There are two different filler hoses: With or without Evaporative Emission System.
If it has Evap/Em, there will be a charcoal cannister mounted on the frame rail adjacent to the alternator. Nestled into the top of the fuel tank is a round fuel vapor valve, with a line routing from it to the cannister.
The hose has to be made from neoprene rubber, otherwise it will rot out within a very short time...whether it's parked inside the Biosphere or not.
I have a similar issue with this '79 F350 C&C dump truck I just bought. I went to put fuel in an it's dripping from the filler hose. The only redeeming grace is.......I can raise the dump bed and easily get to the fuel filler hose.
My question..to draw from your well of knowledge.....is this hose the same PN for a truck that had a standard bed with the side mount tank?
Where the hose goes over the top of the frame rail it's sorta flattened a bit.
VIN # F37SUDG6903
Thanks,
Whit
Bill,
Prolly not...will know for sure when you answer the two questions I asked.
VIN # F37SUDG6903
VIN # F37SUDG6903
Mid-ship or aft axle fuel tank? With/without Evaporative Emission?
These hoses are a PITA to look up, because there is no catalog sequence. The applications jump around from year to year, Regular to Crew to Super Cab, then back to Regular Cab, with Econolines tossed into the mish-mash.
The section of the filler hose that is flattened is supposed to be that way.
Yes, styleside pickup w/aft axle fuel tank, w/o Evaporative Emission System...
Funny that this came up, I've been tackling the same project today. I went a different route and bought bulk hose from the local parts store. I can't say anything for the longevity, but just be sure you get the type of hose certified for gasoline, i had one place send me home with a piece of 3/4" heater hose instead of 3/4" vent hose. You can reuse the metal plates from the old hose and clamp it all together with some big hose clamps.
Sam
Sam
Just received my new side mount gas tank but since the old one was taken off some years ago I have forgotten how to mount the sensor and float. It looks like it will hang down for the float to move correctly but I would like to see a diag. Any suggestions where to locate. Book is not much help. I have the hoses from LMC and all looks to be quality. I think I had a canister on this '79 Ranger F150 but not sure. Does it help with determination of the hoses?
Last MSRP: $71.45 / Dealer net cost: $42.87.
Applications: 1975/77 F100/350 Super Cab / 1975/78 F100/250 Regular Cab Styleside/Flareside pickups.
DON SANDERSON FORD in Glendale AZ has 1 = 623-842-8648.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 22 = 800-476-9653.
swcash
13
04-03-2024 10:24 AM
Bookman
11-22-2004 04:30 PM
1969f100
02-19-2003 11:23 PM
tuffguy
06-17-2002 02:40 PM
