Fuel opening to gas tank hose 76 F150 - Ford Truck Enthusiasts Forums
Old 01-10-2012, 10:02 PM
charkane charkane is offline
charkane is starting off with a positive reputation.
Anyone have any suggestions where to get a good quality hose that runs from the fuel-neck-opening to the rear gas tank. I usually get it from LMC truck, but they all dry rot and leak after and year or so (live in southern AZ). Royal pain dropping the gas tank just to install this hose every..year. Any other sourcing suggestions would be much appreciated.
<O</O
Thanks.
Old 01-11-2012, 02:40 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by charkane View Post
Anyone have any suggestions where to get a good quality hose that runs from the fuel-neck-opening to the aft axle gas tank.
<O</O
Thanks.
The hose has to be made from neoprene rubber, otherwise it will rot out within a very short time...whether it's parked inside the Biosphere or not.
Styleside pickup w/aft axle fuel tank: There are two different filler hoses: With or without Evaporative Emission System.
If it has Evap/Em, there will be a charcoal cannister mounted on the frame rail adjacent to the alternator. Nestled into the top of the fuel tank is a round fuel vapor valve, with a line routing from it to the cannister.
Old 01-11-2012, 05:49 AM
FineSeventyNine's Avatar
FineSeventyNine FineSeventyNine is offline
Tennessee Hillbilly
FineSeventyNine is gaining momentum as a positive member of FTE.
Bill,
I have a similar issue with this '79 F350 C&C dump truck I just bought. I went to put fuel in an it's dripping from the filler hose. The only redeeming grace is.......I can raise the dump bed and easily get to the fuel filler hose.
My question..to draw from your well of knowledge.....is this hose the same PN for a truck that had a standard bed with the side mount tank?
Where the hose goes over the top of the frame rail it's sorta flattened a bit.
VIN # F37SUDG6903
Thanks,
Whit
Old 01-11-2012, 06:56 AM
Quote:
Originally Posted by FineSeventyNine View Post
Bill,
Prolly not...will know for sure when you answer the two questions I asked.
VIN # F37SUDG6903
F37 = F350 2WD Cab & Chassis.
Mid-ship or aft axle fuel tank? With/without Evaporative Emission?
These hoses are a PITA to look up, because there is no catalog sequence. The applications jump around from year to year, Regular to Crew to Super Cab, then back to Regular Cab, with Econolines tossed into the mish-mash.
The section of the filler hose that is flattened is supposed to be that way.
Old 01-11-2012, 07:27 AM
Tennessee Hillbilly
Mid-ship tank.........w/o evap
Old 01-11-2012, 10:15 AM
Hi Bill,
Yes, styleside pickup w/aft axle fuel tank, w/o Evaporative Emission System...
Old 01-11-2012, 07:33 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Just an idea ...I'm using a clear fuel hose that I got from either Jaz fuel cells or Summit. I can't comment on longevity other than 1 1/2 years of being installed with fuel in the barn.
Old 01-11-2012, 09:28 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250 Rusty_Old_F250 is offline
Rusty_Old_F250 is gaining momentum as a positive member of FTE.Rusty_Old_F250 is gaining momentum as a positive member of FTE.
Funny that this came up, I've been tackling the same project today. I went a different route and bought bulk hose from the local parts store. I can't say anything for the longevity, but just be sure you get the type of hose certified for gasoline, i had one place send me home with a piece of 3/4" heater hose instead of 3/4" vent hose. You can reuse the metal plates from the old hose and clamp it all together with some big hose clamps.
Sam
Old 01-13-2012, 08:19 PM
texanrick's Avatar
texanrick texanrick is offline
texanrick is starting off with a positive reputation.
Just received my new side mount gas tank but since the old one was taken off some years ago I have forgotten how to mount the sensor and float. It looks like it will hang down for the float to move correctly but I would like to see a diag. Any suggestions where to locate. Book is not much help. I have the hoses from LMC and all looks to be quality. I think I had a canister on this '79 Ranger F150 but not sure. Does it help with determination of the hoses?
Old 01-13-2012, 11:49 PM
1976 F150 Styleside pickup w/aft axle fuel tank, w/o Evaporative Emission System.
D5TZ-9047-A .. Aft Axle Fuel Tank Filler Hose-Use without Evaporative Emission / Obsolete
Last MSRP: $71.45 / Dealer net cost: $42.87.
Applications: 1975/77 F100/350 Super Cab / 1975/78 F100/250 Regular Cab Styleside/Flareside pickups.
DON SANDERSON FORD in Glendale AZ has 1 = 623-842-8648.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 22 = 800-476-9653.
Old 01-14-2012, 05:17 AM
DKW 86's Avatar
DKW 86 DKW 86 is offline
DKW 86 is starting off with a positive reputation.
Many Advance Auto Parts stores carry it in their commercial side.
2000 Ford Expedition xlt battery saver relay clicking no start websurfer 1997-2006 Expedition & Navigator 13 11-14-2016 02:22 PM
Sensors and Locations Hawk180 1999 - 2003 7.3L Power Stroke Diesel 4 12-21-2012 08:06 AM
Long to Start Rough when running 2003 Help Jnas860 6.0L Power Stroke Diesel 20 07-02-2012 02:19 PM
1985 F250 - Electric Fuel Pump Problems BigJim_610 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 12-13-2009 11:42 PM
wuddya guys think? FFemt5287 1994.5 - 1997 7.3L Power Stroke Diesel 11 01-02-2009 12:42 PM
Tags
05, 150, 1973, 1976, canister, f100, f150, f350, ford, fuel, gasonline, hose, lines, tank, vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
