Ignition Problems again
Problems again!
The truck is a 1991 F150 Auto Transmission 4x2
We switched the actuator, it was partitally snapped but still held so we changed it anyways. But when we got everything put back together the problem consited.
Problem: Doesn't want to stay running unless you hold the key. IT also turns off if you grab the steering wheel getting out of the truck. It will run all the accesories but you have to find the "magic spot" which seems to be about 2/3 of the way to turn on just the accesories.
I need help soon because I have to get the oil pan switched before spring. I don't like oil all over my yard and garage.
Thanks,
Alex
Thanks,
Alex
Received 3,090 Likes
on
Can you explain in more detail on how to do this? It looks like new wiring has been put in the steering column by the looks of the wires. Just thought I would mention that. I also picked up a fuse type thing that is supposed to go in the steering column.
kevinfromwebb
11-24-2018 06:02 AM
Lord Vokk
11-16-2016 10:51 AM
