Difference between F250 and F350 SRW? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-10-2012, 02:23 PM
Studawg's Avatar
Studawg Studawg is offline
Thread Ender
Studawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to all
I have seen different things in different places regarding this. What are the difference between an F250 and an F350 Single rear wheel truck? Are the front axles the same? Rear axles? Different rear springs?
Old 01-10-2012, 02:44 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
1. The size of the blocks between the rear axle and the rear springs.
2. The GVWR number printed on the B-pillar tag.
3. The number on the badges on the front fenders.
...no more... no less.
Old 01-10-2012, 03:35 PM
FishingNut's Avatar
FishingNut FishingNut is offline
FishingNut has a great reputation on FTE.FishingNut has a great reputation on FTE.FishingNut has a great reputation on FTE.FishingNut has a great reputation on FTE.
3 rear leaf springs on the 350 vs 2 on the 250
7K lbs rear axle load on the 350 vs 6K on the 250
and of course what was mentioned previously...
I just went down this road as I have upgraded to the 350 from another 3/4 ton truck because of load requirements.
Old 01-10-2012, 03:46 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Depends on the model year mainly:
* Up til about 2004, 4 wheel drive F250s got D50s while F350s got the D60.
* F250s typically get the upper aux spring as part of a package, while F350s usually have them no matter what.
* After 2011, F250s have one fewer leaf and vacuum boosted brakes while F350s get hydroboost (diesels only).
* V10s with factory 4.30 gearing get the Dana Super 60 7000# GAWR front axle.
* Up until at least 2008, F250 2wd - no spacer, F250 4wd - 2" spacer, F350 2wd - 2" spacer, F350 4wd - 4" spacer
It's easier to list what are identical (or substantively so) inside a MY:
- Frame
- Rear Axle
- Rear main leaf pack (through 2010)
- Front springs (rating is dependent on package and engine mainly, but any ratings of spring should physically fit in a truck the relevant major year ranges of 99-04, 05-07, 08-10, 11+)
- Engines
- Wheels and tires
- Sheet metal and trim
- Availability of certain options are package and trim-based and not badge-based, (but might be standard on 350s and optional on 250s) - cab lights, alternator upgrade, snowplow package, block heaters (or cord, as relevant), access controls, powered accessories, interior upgrades, etc
Old 01-10-2012, 03:50 PM
Studawg's Avatar
Thread Ender
99 to 03 7.3s are what I am interested in. For instance an 03 F350 4x4 is gonna have a Dana 60 up front and an 03 F250 4x4 will have a Dana 50 up front?
Old 01-10-2012, 04:00 PM
Disgruntled Texan
Yes, a 2003 F250 could possibly have a D50 rather than a D60. I don't know exactly at what point the switch was made, it seems to me that F250s started getting the D60 in late '03, but they might have started as early as the 2001-2 MY. Excursions apparently all got the D50, I don't know if that continued through 04-05 when the platform ended. Other than that, they're substantively identical except for what Texas Rebel specifically mentioned.
Other than a GAWR of 5000# instead of 6000# and a smaller ring gear/pinion, there's nothing "bad" about the axle in a stock application. Nothing I would not buy a truck over at least.
Old 01-10-2012, 04:17 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
read post #4 and #5 by YETI.
http://www.ford-trucks.com/forums/49...lder_____.html
this info is from the tech folder at the top of the superduty section.
F250 vs F350 rear springs? The same? whalerron 1999 to 2016 Super Duty 3 11-18-2015 10:03 AM
F250 vs. F350 AKHunter93 1987 - 1996 F150 & Larger F-Series Trucks 21 06-01-2015 06:05 PM
F250/F350 Rear Axle Rating mcguirehg 1994.5 - 1997 7.3L Power Stroke Diesel 1 01-29-2014 08:04 AM
F250/350 Difference for 2005 and later rprice 1999 to 2016 Super Duty 17 04-29-2005 07:04 AM
Diiference between a single wheel and dually axle jday92591 Clutch, Transmission, Differential, Axle & Transfer Case 5 11-30-2003 11:35 AM
Tags
beyween, differance, difference, differenced, differences, differents, duty, f250, f350, ford, forum, interior, size, srw, super, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
