Exhaust manifold leak - Ford Truck Enthusiasts Forums
Old 01-10-2012, 02:35 PM
foreverfordtrucks foreverfordtrucks is offline
foreverfordtrucks is starting off with a positive reputation.
Hey guys need a little help here,rebuilt the heads on my 81 460 and they have no war page,but the passenger side exhaust manifold haas an exhaust leak. Could the exhaust manifold be warped ? Is this a common problem?
Old 01-10-2012, 06:31 PM
redmondjp's Avatar
redmondjp redmondjp is offline
redmondjp is gaining momentum as a positive member of FTE.redmondjp is gaining momentum as a positive member of FTE.
I don't know about common, but it can definitely be warped. Are you using exhaust gaskets or bolting directly to the head? A machine shop can surface it to restore flatness of the sealing surface, if needed.
Another possibility, one which is more likely IMO, is a small crack. They can be really hard to see if on the engine side.
Old 01-10-2012, 06:55 PM
I used brand new gaskets,I will check for cracks.thanks
Old 01-12-2012, 08:59 AM
fasthauler's Avatar
fasthauler fasthauler is offline
fasthauler is gaining momentum as a positive member of FTE.
Hopefully the shop that rebuilt the heads should have checked for any warpage at the exhaust ports. Shame on them if they didn’t. The exhaust manifold will usually pull up tight to the head if torqued properly unless it is major warped. My guess would be a crack somewhere. Start the thing up and, while still cold, just run you’re bare hand around the manifold. You should definitely feel it if it is leaking. I am guessing that this is happening on the right side manifold. That is the one that usually causes the problem.
Old 01-12-2012, 08:24 PM
Yea it's the right side, I will check for that thanks.
Old 02-17-2012, 09:29 PM
well the exhaust leak is all good now thanks for the help! the problem now is i had to pour a little gas in the carb to get it to run.it took a couple times repeating this then it stayed running and ran great for about 20 minutes then stalled,coudnt get it to start again.it was low on gas and had been sitting for awhile.today i added about 5gallons of premium gas and tried starting it again with no luck.when i put gas in the carb it would fire rite up untill the gas was used.will only start now when i add gas to carb but wont stay running!could it be the mechanical fuel pump?is there away to test the fuel pump?any advice would be appreciated
Old 02-18-2012, 12:08 AM
Sevillian273's Avatar
Sevillian273 Sevillian273 is offline
Sevillian273 is starting off with a positive reputation.
Fuel filter.
Old 02-18-2012, 12:29 AM
460 starved
I changed the inline filter going to the carb,do you know if there is another one inline somewhere?this motor is in an e350 motorhome.
Old 02-18-2012, 08:49 AM
bigbluebronco43 bigbluebronco43 is offline
bigbluebronco43 is starting off with a positive reputation.
What was the fix on the exhaust manifold? I'm having the same leak on my 97 f250? I'd think your fuel pump is bad if you replaced the filter.
Old 02-18-2012, 09:55 AM
fasthauler's Avatar
I have seen guys do major battle with their fuel pumps and find out the pickup screen in the tank is plugged. This happens a lot more than people think. The gas nowadays is really dirty and will eventually plug that little screen that is on the end of the pickup tube that is in the gas tank. The difficult fix is dropping the tank and removing the pickup tube and replacing the screen. The easy fix is to put a blow gun on the gas line to the tank and with as much pressure as the air compressor is able to put out, blow the darn thing off of the end of the pickup tube. Then put a filter in the gas line before the fuel pump. That way it will be easy to clean the filter next time without taking the gas tank down. The easiest check to see if this pickup tube filter is plugged is to pull the gas line loose where it comes from the tank to the fuel pump and suck on it. If you get a mouth full of gas then it is not plugged.
Since it is not a good idea to get a mouthful of gas find an alternate way of providing suction on the line. One of the simplest ways would be to go to the hardware store and buy a length of clear vinyl tubing the size of the gas line. Put the vinyl tubing on the end of the gas line and then suck on the vinyl tubing. If you see gas coming up the vinyl tubing quit sucking. If gas is present in the tubing you should be able to lay the tubing on the ground, preferably in a container, and the gas should flow freely. If not then the filter is probably plugged. (Or nearly plugged) These kinds of problems can really plague you, so good luck.
Old 02-18-2012, 01:59 PM
460 starved
thanks for the advice i am going to try that before changing the pump!getting back to my exhaust manifold,i was going to switch out to headers since people were telling me thats how they got rid of there exhaust manifold leak.Before doing that as one last resort i went over the the bolts retorqueing them one last time when the engine was warm,so far knock on wood I have not had any more exhaust manifold leak!For now i will leave that alone!So close to having this motor done hopefully this fuel issue is the last problem.
Old 02-19-2012, 07:30 PM
starved 460
so I pulled the fuel line from the carb and turned over the motor got good fuel pressure out of fuel line so i guess the fuel pump must be ok .hooked line back up to carb and it still wont start? still starts when adding gas to top of carb but wont stay running.has anybody had this prob before ?
Old 02-20-2012, 01:51 AM
redmondjp's Avatar
Quote:
Your float in the carburetor may be stuck in the 'up' position. Is there any gas in the bowl of the carb? You can usually tell by operating the throttle - if the accelerator pump squirts fuel down the venturis when you do this, then there is fuel in there (unless your accelerator pump doesn't work).
When is the last time that the carb has been rebuilt? You may be due.
Old 02-22-2012, 12:34 PM
starved 460
so guys looks like my accelerator pump doesnt work.dont think this carb has ever been rebuilt.before i rebuild this i found another holley the exact same as mine that has been rebuilt but it has an electric egr valve instead of vacum,would this be easy to adapt to my 81 460 or would it be to much work?I dont know what year this other carb is other than its identical to mine with electronic egr.any advice would be appreciated
Old 02-22-2012, 06:34 PM
redmondjp's Avatar
If it bolts in place and has the same throttle and transmission kickdown levers, I'd go for it. Nothing to lose at this point.
And I think you probably meant to say electronic choke instead of EGR - you will have to connect that to the stator output of the alternator (check a Ford wiring diagram to confirm this). Electric chokes are connected to the alternator so that they will only be powered up while the engine is running (as opposed to when the ignition is on).
You can connect the electric choke to a switched ignition source, but just remember NOT to leave the key on for very long w/o starting the engine, when the engine is cold (the choke will warm up and open too soon).
Ford 226 Oil Exhaust leak at manifold, heat riser? Vegas123 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 01-27-2016 06:53 AM
Manifold to pipe leak fix? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 2 07-22-2015 12:16 PM
Exhaust Manifolds ? sonny1965 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-16-2015 04:04 PM
exhaust leak jawdoc 2007 - 2014 Expedition & Navigator 1 11-18-2014 07:45 PM
Exhaust Leak Jared32676 1997 - 2003 F150 8 04-16-2014 08:44 PM
Tags
77, enthusiasts, exhaust, f250, fe, ford, forums, leak, leaky, machine, manifold, manifolds, manifoldsnh, moter, shop, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
