Should I change my own transmission fluid or take it to a shop? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-10-2012, 11:02 AM
4x4countryboy 4x4countryboy is offline
4x4countryboy is starting off with a positive reputation.
Question Should I change my own transmission fluid or take it to a shop?
Is there any harm in me changing my own transmission fluid? I have a 2001 F350 4x4, are there any videos out there or instructions on changing the fluid?
Also is there anything I should check or change other than the fluid and the filter while I am under there?
Got a day off work due to rain so trying to be productive....lol
Thanks ya'll! Taking my truck to the shop later today to get the codes read and see why the S.E.S. light comes on occasionally, hopeing that goes well!
Old 01-10-2012, 11:05 AM
rufushusky's Avatar
rufushusky rufushusky is offline
rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.
I followed this method basically:
TikiWiki : 4R100 Transmission Fluid Flush
I drained the pan, refilled it, pumped out a gallon, refilled a gallon...repeated until I did 20 quarts. Worked like a charm.
Old 01-10-2012, 11:10 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Be advised that Mercon V has been reformulated and can now be used in the 4R100.
Mark Kovalsky Tranny Flush
Old 01-10-2012, 11:29 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
^^^^I also used Mark K's method and it works great. Prior to that I used to take my truck to the dealer for their "trans fluid flush". I later found out that all they did was drop the pan and drain the convertor and refill with new fluid so only half of the oil was getting changed out. Mark's method is more like a full fluid transfusion and it's remarkably easy to do. If you follow his method exactly, then you will pump out about 6 qts before you have to fill up the pan again. In my opinion this is ideal because then you have a pan full of clean fluid and it will only take 3 cycles before you have flushed the entire system (about 18 qts including cooler). I buy 20 qts of Mercon V when I change my fluid because I usually need to add a little at the very end of the procedure.
I am getting ready to change the trans fluid on my 3 trucks this weekend if I can round up enough trans fluid. I am going to try and find Mobil 1 syn in 5 gallon buckets since I think that might be a little less expensive than 60 qts of Motorcraft Mercon V.
Old 01-10-2012, 11:38 AM
jdshookup jdshookup is offline
jdshookup is starting off with a positive reputation.
It's as easy as rufu said...
Old 01-10-2012, 12:06 PM
SARDiverDan's Avatar
SARDiverDan SARDiverDan is offline
SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.
Changing mine on Thursday. I also have an issue with locating enough Mobil 1 to do the job. Many of the local auto parts places only carry a few quarts at a time. Luckily, I went into an AutoZone and they just put out 30 quarts so I bought them all as I need 26 quarts for a change.
Old 01-10-2012, 12:13 PM
rufushusky's Avatar
Yikes! 30 quarts of Mobil 1...that must have put a dent in the wallet. I guess I am the only cheapy running Super Tech Dex/Merc with lubegard?
Old 01-10-2012, 02:04 PM
the Mobil 1 synth. I saw was 9.99$ a qt...that would be a $200 trans. change...lol thats alota $$$. I opted for the Mercon V
Old 01-10-2012, 03:55 PM
Joe_914's Avatar
Joe_914 Joe_914 is offline
Joe_914 is gaining momentum as a positive member of FTE.
When I did mine a couple months back I drained the pan changed the filter then rolled the motor over till the torque converter plug was accessible after removing the cover plate. Drained the converter and then filled the trans back up.
Nearly any idiot can do this.
Old 01-10-2012, 04:41 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
I dony know about how much more Mark s flush gets out versus dropping the pan and draining the tc, I did an 02 for my boss and it took 18 quarts total.
Old 01-10-2012, 07:55 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Quote:
Dropping the pan won't get that much out. They stopped putting the drain plug in the torque converter so only getting out a few quarts from the pan won't help much on many trucks.
Mark's version also flushes the lines, cooler and valve bodies. Simply draining won't do that. If you're lucky enough to have a plug in the torque converter, you can still use Mark's flush procedure. You're just ahead of the game since you don't have as much old fluid to flush out.
Old 01-10-2012, 09:19 PM
Dean88's Avatar
I didnt realize they quit putting plugs in the tc. When did they start that? I worked on a ranch for three years that had 7 psds, two had autos, and the 95 & the 02 both had plugs in the tc. I did all the maintences on the trucks, and when I left the 02 still had the orginal tranny with 300k on the clock, the other auto, 95, had orginal tranny but a new tc at 250 k.
Old 01-10-2012, 09:31 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is online now
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
I am curious if my early 99 has a plug in the tc then.
Old 01-10-2012, 11:00 PM
1L243's Avatar
1L243 1L243 is offline
1L243 is gaining momentum as a positive member of FTE.1L243 is gaining momentum as a positive member of FTE.
I do it the same every time... I take it to the Cheveron Lube place. I get out and go into the office and watch through the window drinking steaming hot coffee. They hook up the truck to the Trans fluid transfer machine.. It uses the Trans pump to transfer the fluid. You see the new stuff going in and the old stuff coming out... In about 30 minutes I pay them $99.99 and I drive out... They do not drop the pan and I prefer it that way.
Old 01-10-2012, 11:33 PM
Dean88's Avatar
I would flip out if they never dropped the pan, because I want the filter changed and magnet cleaned/ checked for large debris.
Transmission fluid change Ben460 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-26-2015 03:28 AM
C6 slipping and transfer case question AZRRC 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-22-2014 01:31 PM
Automatic transmission fluid change sbrodacz 1987 - 1996 F150 & Larger F-Series Trucks 2 03-07-2013 01:33 AM
Changing transmission fluid - OEM fluid? cecilt 1999 to 2016 Super Duty 26 11-02-2012 06:26 PM
05 F-150 5.4 4x4 XLT Transmission Fluid Change bighunt34 2004 - 2008 F150 73 01-13-2012 10:29 AM
Tags
460, atf, change, due, f350, fluid, ford, fuild, it, oil, procedure, super, superduty, tech, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
