fender rot / covers ?
Dont just cover it. Cut out the old inner fender wells and clean it all up from the inside. Cut out all the nasty areas clean and go to a junkyard and find a decent truck with good fenders and weld back in.
From there you can build your own inner fenders, as what I'm doing and it shouldwork out nicely
THREAD RESURRECTED
I also have the usaual rot on the rear fenders of my 93 Bronco. Being new to trucks when I first looked at it I figured I was just cut out the rusted area and install fender flares. I didnt realize how aggressive/wide cut-out flares were and im not looking for something huge. Basically I want to avoid spending money on having patch panels welded in just to cover it up with fender flares.
So are there any flares that can be attached without them being huge and without needing the mounting points of the stock trim? Can someone give me an idea of how much it might cost to have two quarter panel patches welded in with/without paint?(I live in Northern Virginia just south of DC) Obviously theres a lot that depends on the cost but I don't know a thing about welding.
THREAD RESURRECTED
i have fender flares covering up my rust but do not know what kind they are they were on their when i got the truck.....and it makes complete sense for one they can make your truck look rust free and dang good....and ive seen so many hideous patch jobs of the rear fenders it isnt even funny or of course a new bed but that is alot of work and money
+2 on fixing it right. The rust will never go away and will only get worst until you cut it out and replace it with good metal. Now with that being said I did cover my up with flares for the time being. You can check out the pics about half way down page 3 of my build thread
https://www.ford-trucks.com/forums/9...0-build-3.html
I will pull these off in a few years, when I have more time for a good prep job and full repaint, and burn in some new steel.
I would try the fender flare mod that you performed, except after looking at my rust bucket when I got home from work a 2" flare will not cover it. I am waiting for an auction next month where I found a good donor vehicle from NC that will help me fix a lot of my issues. I am still looking for a cheaper floor pan as the drivers floor is rusted out and the passenger side needs a little attention too.
If you're going to cover up the rust make sure you clean out the really bad, loose stuff, hit it with some rust converter and paint over it. That'll slow it down otherwise the flares will be falling off in a year or two. If you can't mount them because of rust holes where the mounts are then see if you can find a shop to do a quick repair. Who cares what it looks like, as long as it's behind the flare you'll never see it.
