Lets see your dash right now! - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 01-13-2012, 09:55 AM
Cooter55's Avatar
Cooter55 Cooter55 is offline
Cooter55 is starting off with a positive reputation.
I got the steering wheel throught Summit. It's a Billet Specialties.
  #62
Old 01-13-2012, 04:56 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Here are 2 pics of my dash. Just plain stock! The dash was painted when the body was painted. I painted the steering column, brake and clutch pedals, the emergency brake, the gear shift lever, the turn signal switch, the kick panel retainers, and the cowl vent handle with a rattle can. I painted the trim to the instrument panel, swiped the indicator needles with red paint, and cleaned the black and silver paint on the inside of the panel. I know this is not part of the dash but I now have a better steering wheel in place.....
  #63
Old 01-13-2012, 09:30 PM
jon6foot4's Avatar
jon6foot4 jon6foot4 is offline
jon6foot4 is starting off with a positive reputation.
I have an early Bronco instrument cluster with electro-illuminescent kit and lightly tinted glass to go in this hole...
Pic is a little older, but the dash itself has not changed since this was taken...
  #64
Old 01-15-2012, 01:48 PM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
Quote:
Originally Posted by Cooter55 View Post
Here's the dash in Cooter, my '55
Really nice looking dash.
I was just woundering where you have gotten the brake and cluth configuration from??
Thanks
  #65
Old 01-15-2012, 03:47 PM
Cooter55's Avatar
Thanks
Thanks, the pedal assembly with master cylinders is from Kugel Komponents.
  #66
Old 01-15-2012, 04:10 PM
carbs & chrome's Avatar
carbs & chrome carbs & chrome is offline
carbs & chrome is starting off with a positive reputation.
Nothing fancy here. Still needs a little work.
  #67
Old 01-15-2012, 08:56 PM
mytbtruck's Avatar
mytbtruck mytbtruck is offline
mytbtruck is starting off with a positive reputation.
Mine is kinda simple but I like simple.
  #68
Old 01-26-2012, 12:03 AM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
  #69
Old 01-26-2012, 12:15 AM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Let me ask you guys with the beautiful dashes - I've had one recurring problem with mine. The stupid glovebox won't stay closed beautifullly like you guys. Are you using some secret method for keeping them closed like that? Mine is a 1950 F1 & has some sort of c-clip thing that honestly doesn't work that well.
Is there some hidden latch you are using? Magnets?
Thx
Ben in Austin
  #70
Old 01-26-2012, 02:14 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Thx
Ben in Austin
Ben, mine stays closed because of that C-shaped spring. Maybe yours has lost it's springiness? It's attached to the right hinge.
  #71
Old 01-26-2012, 07:13 AM
mine took a lot of tweaking and a new spring. i read on here somewhere of someone using a magnet off one of those cheap retrieval magnets and gluing it to the spot one of the rubber bumpers go
  #72
Old 01-26-2012, 09:10 AM
ben73058's Avatar
Thanks Joe & Joel,
I've always admired both of your trucks. Sometimes it's the little things -
the glovebox door bangs open while you are driving - squares the crap out of you. I'll try a new clip - do you recall which parts place you got it from? The hardware store has some magnets - I'll try that as well.
I'm wrangling with the transmission shifting early & I'm hitting somewhere up in the front left wheel area - Big things always get the most attention but sometimes the little one's are even more aggravating.
Any hints on getting the little vent windows closed - I replaced everything & now it's a bear to get them closed. They are pretty pricey so I don't want to break them again by pressing too hard....
Thanks guys.
Ben in Austin
  #73
Old 01-26-2012, 10:26 AM
Just another Joe
Ben in Austin
My spring is original equipment, and it was kind of a pain to install it. But I see Dennis Carpenter has the spring for $5:
GLOVE BOX SPRING 1948-1952 # 8C-8106068
No idea where they're made...
  #74
Old 01-26-2012, 10:40 AM
ben73058's Avatar
Thanks Joe!
I appreciate it.
Ben in Austin
  #75
Old 01-26-2012, 11:37 AM
eman92082's Avatar
eman92082 eman92082 is online now
Monkey-Face in Your Face!
eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.
[/quote]
THAT is a great looking dash. My favorite gauges (as in my dash) Very Nice !
** truck7575 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 08-02-2015 10:53 PM
Rough country lift, good or bad? bigcountry62 1973 - 1979 F-100 & Larger F-Series Trucks 16 04-26-2013 01:52 AM
What is a good peep mirror for my effie Björn 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-04-2011 05:13 PM
tech clane Arizona Chapter 4 12-16-2010 09:28 PM
April Chat helifixer Arizona Chapter 297 05-01-2010 06:41 AM
Tags
1949, 1978, 54, air, brake, dash, davidson, f1, f100, ford, fxs, glass, guages, harley, pictures, rusted
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
