2003 F250 6.0 tow/haul light flashing - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-10-2012, 07:53 AM
19Ford69 19Ford69 is offline
19Ford69 is starting off with a positive reputation.
Hey Gentlemen,
Having a problem with my S/D and thought I would ask for some suggestions. When the truck is first started up in the morning, I will let it warm up for around 5-10minutes before driving and the tranny gauge shows warm but the engine is not in the warm range yet. If I put it in drive and start down my road, the truck seems fine but when it shifts into 2nd while I am lightly pressing on the accelerator pedal, it will lose power for a second then come back. If I continue down my road till I hit the stop sign 1/2 mile later and slow down to stop, the tow/haul light comes on. I have to shut-off the truck and re-start and then I don't have the problem the rest of the day if I am driving it. But once it gets cold over-night it will do it yet again.
I haven't taken it to Ford to see what the codes are that are thrown since I imagine they will try to get me to have work done that may not fix the problem but end up costing me more money then I have at the moment. Any suggestions on what could be causing this?
Thanks Bill
Tow mode engine braking jd350b 6.7L Power Stroke Diesel 11 06-11-2016 10:45 PM
Loud Noise With Tow/Haul Mode BigDaddy_2 6.7L Power Stroke Diesel 22 10-03-2015 01:41 AM
Trans Problems- Codes n flashing lights Dominating 6.0L Power Stroke Diesel 15 06-16-2012 06:21 PM
2005 F350 Trasmission Problems / Tow-Haul ROKNTB 1999 to 2016 Super Duty 4 10-12-2006 03:57 AM
Check Gauge - Tow/Haul Flashing Bosko 6.0L Power Stroke Diesel 10 01-18-2006 08:23 AM
Tags
03, 2003, 250, 60, blinking, duty, f250, f350, flashing, ford, haul, light, moisture, super, tow, towhaul
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
