Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-09-2012, 09:31 PM
jjurva jjurva is offline
Garage is empty, add now
jjurva is starting off with a positive reputation.
The Beggining of a 1960 F100 Project
I have a 1960 f100 custom cab 4x4. What engine is in it? Will the carb need rebuilt? It has sat for up to ten years. Also the axle has snapped right next to the differential. Do you guys have any good ideas on how to get a new one. And as long as I'm asking questions ; if you do know what engine i have what mpg can I expect to get?
  #2 (permalink)
Old 01-10-2012, 01:36 PM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 is gaining momentum as a positive member of FTE.Buzz44 is gaining momentum as a positive member of FTE.
Post up your trucks vin #s and if Bill (Numbersdummy) is scanning this forum he will be able to tell you what the truck had when it rolled off the assembly line. He may be able to tell you what year trucks beside yours that you will be able to harvest a new rear end out of to replace your broken one. Make sure you list all numbers on that tag if you can find it. Others here may be able to help you too. I play with these trucks in the relm of 61-66 so dont know alot about the fridges. Good luck.
__________________
1965 F100 4x4 for fun. Name Gentelman Jim
1963 F250 4x4 for restore. Name Beast
1998 F150 4x4 for daily use. Name Birthday Boy
2001 Ford 4x4 Explorer Sport Trac (nice but sucks on MPG its underpowered)
Vic by the way.
  #3 (permalink)
Old 01-11-2012, 08:42 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Quote:
Well, can you tell us if it has 6 or 8 cylinders? If the truck has been sitting for ten years, the carb has more than likely all dryed out and has quite a bit of gum in it. Yes, it should be torn down and reassembled with new gaskets and needle valve (rebuild kit), at the minimun. Have you had the rear end apart to see the broken axel? Have you tried doing a search of this forum for these type of questions? There is a ton of info that has already been typed out several times.
  #4 (permalink)
Old 01-11-2012, 09:54 PM
59flatbedford 59flatbedford is offline
59flatbedford is starting off with a positive reputation.
Well we really can't say what engine you have but we can tell you what engine it should have. For V8 it should have the 292 and for I6 it should be a 223 (i think). Now if thats what in there now who knows. Since its 4x4 it might very well have been messed with in the past. The 4x4s are fairly uncommon so its possible that it might have been converted to 4x4 with a whole new drive train. Heck it might even have a chevy drivetrain in it. If it is the 292 it should have a goofy cross over exhaust system on the front of the motor and two valve cover bolts per side. A useful link maybe.
Ford V8 Engine Identification - FORDification.com
Assuming the Axel is a ford 9in parts should be easy to find for it and available at every local salvage yard and aftermarket supplier. some pictures might help identify just what you have.
__________________
Yes its dented, Yes its scratched, But at least i drive it.
Turquoise 1964 F250 4x4 (Barney)-352 V8, 4 speed, flatbed, and AM radio.
1959 F100 (pile of parts)- still a work in progress.
  #5 (permalink)
Old 01-11-2012, 11:04 PM
From what you have to say I am pretty sure I have the 292 it has the cross over exhaust you were talking about. Would the vin tell me if the truck came stock 4x4 or is there another easy way to tell. I think it came stock like that but who knows.
  #6 (permalink)
Old 01-12-2012, 09:39 AM
yea the Vin will tell you what was stock on it. easiest thing to do would be to post the vin hear and someone will be able to decode it.
__________________
  #7 (permalink)
Old 01-12-2012, 07:15 PM
spurredon's Avatar
Here's a decent link for decoding your VIN number.
1960 Ford Truck VIN
Tags
1960, differential, f100, motor, pitchers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
