Horn and headlights
Horn and headlights
Got a little work done on the '66 today. Installed my new turn signal switch, put new horn brushes in, and finished grinding the top of the new power steering column so I could reinstall my original horn ring. When my horn still didn't work, I bought a new horn relay from NAPA and now it works great. I also installed a set of Cibie lamps with H4 bulbs and upgraded my wiring harness with relays. My lights are every bit as bright as a new car now. My old lights were so dim they looked yellow.
I bought my harness from Reenmachine. He designed them for Mustangs, but they work fine for our trucks. The harness was very well made. It wasn't cheap and you could make your own for a lot less. I have seen an article on FTE which describes how to make one. Here is the link if you are interested:
Reenmachine :: Modern Lighting :: H4 Halogen Headlights & Wiring Harnesses :: High Power Relay Headlight Harness, 2-Light H4 System - The website for reenmachine Incorporated, builders of exotic custom vintage Ford Mustangs with a high-tech hot rod i
Mark
lamps
Do you think that the new headlamps will add more current thru the on/off switch ??I replaced my headlight switch and the headlights on bright for very long kicks out the reset on the on/off headlight switch. I do not know if the headlights were messed with by previous owner or not... I learn a lot by what all everyone else trys....Dan
Whiter Whites, Brighter Brights .: Articles
Let me see if I got this right...all the article says is add the relays and modify from the relays all the way to each lamp-Right ?? Tie in the existing wiring in at the relays-correct ?? The options of hi-beam flash, and forced low beam sw,, I need not worry about...When my headlights started going out and flashing,, I was told to replace the switch,, I put in a new Borg-Warner..I was glad,, the old stock switch was PITIFUL !!! fell apart. Now as I said, sometimes after 15 minutes of hi-beam,,the new borg will reset...so looks like your article will solve my situation........If I understand that all I have to modify is from relays to lamps,, I am going to do this tomorrow....I did not realize there was as much 18 gau. wire in a truck(stock)..I just assumed it was 14 gauge minimum size...But I will use 14 minimum....Thanks !! Dan
It would be ok to use 18 gauge for the trigger wire with very little voltage. All other wires I would use 12 gauge which I have seen spec'd in many articles I have read on this. The trick is to get top quality relays that say Tyco since they bought Bosch. Also to find headlamp sockets with 14 gauge pigtails rather then the more common 18 gauge.
If you want to see a nice harness in the making complete with pictures and explanation then look at this Dodge truck link. The guy even put it into a .pdf file so you can save it like I did.
Installing Headlamp Relays - Dodge Diesel - Diesel Truck Resource Forums
