2009 Escape Trasmission Problems - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 01-09-2012, 07:43 PM
Captbs32's Avatar
Captbs32 Captbs32 is offline
Captbs32 is starting off with a positive reputation.
I own a 2009 Ford Escape 2.5L 2WD Automatic and I am hearing a high pitch noise like a bearing is going out. Soon after this I started losing trasmission fluid. When I was changing the oil I really investigated. I saw the leak was coming from the trasmission on Driver's side. I grabbed the Trans axle shaft and there was A LOT of play in the bearing and I as I did that tras fluid started leaking out.
So I am guessing it is that bearing making the noise. However, even in park it still makes the noise. First of all, I was wondering what is that bearing and seal called and how difficult it is to replace? Didn't look that hard. Not sure what transmission it is I think it is 6-speed automatic?
Old 01-09-2012, 10:36 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
I would talk to the Dealer this should be a covered fix under warranty.I think there are other compants about the driver side seal failing.2009 was the first year for this transmission
Old 01-09-2012, 11:42 PM
Captbs32's Avatar
unfortunately it is past the 60k power-train warranty. Are you saying it could still be covered because people have had problems
Old 01-10-2012, 07:53 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
The latest TSB is #11-11-30 on this problem which started in late '08 on the first '09MY. The TSB which jas been superceded half-dozen times blamed the the problem on bad surface finish on the seal and bearing diameter. Since the problem still happens on the '11MY, I really can't see this as a parts problem.
I for one think that since it only happens on the driver's side which is the shorter lenght shaft that it's a design issue. It's possible that other variables in other parts and/or location tolerances are causing this problem to come about. Since some owner's have never had the leak, you might want to add just poor QC in their parts.
The half-shaft assembly must be removed from the driver's side to get at the seal and support bushing(no bearing) inside the half-case cover. You'd need to pull the bushing somehow, not sure if one could rent the needed puller?
Old 01-10-2012, 08:10 AM
tomw tomw is online now
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
First think I would do is check the fluid level. With a leak, you never really know how much is left to keep the 'still good' parts from getting ruined by lack of lubrication. I would take it to the dealer to see if there was any 'good will' available to affect a repair. Sometimes they will pay for parts, and charge you 1/2 of the labor to make things right. If there is no help there, take it to an independent transmission shop to see if they can replace the bushing and seal without dropping the transmission. The labor for an R&R is a big pile. Just too many things to disconnect and tie up out of the way before you even get to the point where you can take things apart to determine the problem parts.
If adding fluid stops the noise, you may have dodged a bullet. If it doesn't, then I'd say the things that rotate, idling in neutral, are the flex plate, torque converter, pump impeller, and ... the input shaft from the torque converter will try to rotate, and may rotate the gizzards of the OD planetary gears which then slip inside the direct drive clutch pack, but I'd have to think a bit on that for real details.
The pump is working the whole time the engine is running, and can cause funny noises if the solenoid the controls pressure is goofing off. The output of the pump is not all dumped into the system, at least on CD4E's, and some is fed back into the pump by the pressure solenoid. I would think if that were buzzing or cycling fast, it could lead to funny noises in the transmission.
tom
2002 Escape 3.0L 4wd thumping noise/shaking dhoff024 Escape & Escape Hybrid 5 02-14-2016 03:13 PM
2002 Sport Trac Trasmission question. Veroldendir Explorer, Sport Trac, Mountaineer & Aviator 3 12-13-2015 03:07 PM
2008 f250 5.4 engine and trasmission swap benvas 1999 to 2016 Super Duty 0 12-29-2014 05:35 PM
144 Bellhousing? oddfordjunkie Ranchero & 1961 - 1967 Econoline 2 07-12-2014 12:11 AM
why do straight sticks have taller gears blue924.9 1987 - 1996 F150 & Larger F-Series Trucks 6 01-31-2014 08:51 AM
Tags
09, 111130, 111130b, 2009, code, escape, ford, level, op, problem, problems, recall, transmission, tsb, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
