'61 ford cabover - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
'61 ford cabover
Old 01-09-2012, 03:00 PM
big ole ford big ole ford is offline
big ole ford is starting off with a positive reputation.
'61 ford cabover
I have been offered a 1961 ford cabover i have not seen it except in pictuers yet and have been told it is a diesel anybody got any idea what kind of diesel engine would have come in this truck.thanks for your help
Old 01-09-2012, 10:59 PM
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
The H-series trucks were available in many combinations of engine, transmission and rear axle options. Five Ford big V-8 gas and five Cummins diesel engines supplied the power under the newly designed cab. The V-8 gas engines offered were Super-Duty engines. The H-series trucks were optioned with 401-cu.in. two-barrel and four-barrel, 477 two-barrel and four-barrel, and 534 four-barrel Ford engines. Gas engine models were designated H or HT. Cummins engine options available were 674-cubic-inch NH-180 and NH-195 diesels or 743-cubic-inch NHE-180, NHE-195 or the NH-220. Torque ratings ranged from 504-lbs.ft. at 1,500 rpm for the NH-180 to a whopping 606-lbs.ft. at 1,600 rpm for the NH-220. The NHE or "economy" engines operated at lower rpm, exhaust temperatures and cylinder pressures to improve fuel economy and longevity. Cummins "Pressure-Time" fuel injection was used on the diesels, which was a very simple injection system using a minimum of components. The "PT" fuel-injection system was driven off the engine camshaft. Diesel models were designated HD for single rear axle and HDT for tandem rear axle.
Got it from here: 1961-'65 Ford H-Series cabovers | Hemmings Motor News
Old 01-09-2012, 11:34 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
I'd guess that would be the first question, H or C.
Not sure on which, if any, oil burners were offered in C's in that year.
Old 01-10-2012, 06:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by big ole ford View Post
I have been offered a 1961 Ford Cabover. I have not seen it except in pictures yet and have been told it is a diesel.
Anybody have any idea what kind of diesel engine would have come in this truck?
It cannot be a 1961, because...there are no diesel engines listed in the 1957/63 Ford Truck Parts Catalog "Diesel Engine Application Charts" until 1962.
1961/65: There are two different Tilt Cabs: C/CT Series & H/HT Series.
Without knowing the year and series of truck, it's impossible to determine what diesel it could have. If you post the VIN, once decoded, all this info will be known.
Old 01-10-2012, 07:29 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
what model truck is it ?
Ford had entered the diesel market in 1961 with Cummins-powered versions of the H-Series high tilt cab, designated the HD-Series.
Old 01-10-2012, 08:58 PM
tripleframe's Avatar
tripleframe tripleframe is offline
tripleframe is gaining momentum as a positive member of FTE.
Assuming it is a early model C series, verify the year, since '62 is when Ford first started offering the 330 City size diesel (built by Ford of England) in the C 6000 and C7000 series.
Old 01-11-2012, 02:54 AM
Quote:
No Cummins diesel engine is listed in Ford truck parts catalogs until 1964. There are no diesels of any kind listed for 1961.
Old 01-11-2012, 11:51 AM
cj06's Avatar
he has not even given a model # for his truck and for all any one knows the engine could have been swapped in the last 30+ years !
Old 01-11-2012, 04:02 PM
captradiator captradiator is offline
captradiator is starting off with a positive reputation.
In other words, the H-Series trucks were C-Series trucks on steroids!
Old 01-13-2012, 10:31 PM
This is absolutely correct for the H series.
Old 01-13-2012, 11:09 PM
Quote:
Wonderful, now look in the 1957/63 Ford Truck Parts Catalog under the Diesel Engine Application Charts and/or the Diesel Engine parts lists.
See if you can find one diesel engine listed for any 1961. Lotsa luck, because the isn't one listed...until 1962.
When the OP posts the trucks VIN, once decoded, the series, engine type/size and the year/month the truck was assembled...will be known.
FoMoCo puts all sorts of jazz in sales brochures, doesn't mean they were available. Sometimes, these features are "teasers" to spark demand among the general public.
Old 01-14-2012, 11:17 AM
Quote:
Originally Posted by NumberDummy View Post
Wonderful, now look in the 1957/63 Ford Truck Parts Catalog.
This is your problem, you spent too much time behind parts books, and not enough time in the real world seeing a driving real trucks.Photo from James Wagner "Ford Trucks since 1905"
Old 01-16-2012, 01:53 AM
rummur s.c.'s Avatar
rummur s.c. rummur s.c. is offline
rummur s.c. is gaining momentum as a positive member of FTE.
Thats some pretty good proof though..
Old 01-17-2012, 09:39 AM
Uh huh...
I'm 67 years old, been in this hobby since 1956, have owned 337 vehicles, 84 of them FoMoCo products. Purchased 8 new Ford Trucks, 4 new Ford Cars. Was a Ford partsman for 35 years.
When I see FoMoCo proof that they offered a diesel in 1961, then I'll believe it. All three of my 1957/63 Ford truck parts catalogs, printed in 1965, 1968 and 1970 do not list a diesel until 1962.
Quoting from a book about Ford Trucks, written by James Wagner, who is not connected with FoMoCo, doesn't cut it...IMO.
Old 01-17-2012, 01:38 PM
Bill,
First off, much thanks to you for all your contributions to to FTE. You are an honored and esteemed member here and most all of us have benefited from your knowledge and expertise.
To you and everyone else, please, please let's NOT let this forum end up in spitting matches!
Just my humble opinion...
1959 f100 cabover camper. Justo707 1957 - 1960 F100 & Larger F-Series Trucks 0 04-28-2015 12:58 AM
air bag assist on hold Cabovers fakesnake Large Truck 1 03-28-2015 07:46 PM
i want a cabover jerry101 Ranger & B-Series 5 07-12-2013 10:43 AM
Ladder rack for Excursion wtrmn Excursion - King of SUVs 1 07-04-2012 01:02 PM
Lance camper truck bed wiring Jetmx Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 18 06-13-2011 03:00 PM
Tags
195, 1961, 1964, cab, cabover, coe, duty, ford, fords, heavy, parts, reproduction, series, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
