1990 f350
Received 3,091 Likes
on
on
I'd be doing the math to see how long it will take to get a return on your investment. Maybe someone who has done the swap can give you an idea of mpg difference. I know for the driving I do (rarely over 60mph) I would rather have 4.10's. That being said, I bought a used set of 4.10's for my dump truck from ebay ($50 or so). Sold the 3.55's for the same price, IIRC
Guess my brain thought you had an earlier non-OD trans, sorry for the confusion. Back to my sleeping while appearing to be awake.
Another thought is you could put larger diam tires and get a poor man's bump in gear ratio. Not all the benefit of 4.10 to 3.55 (13.4%), but you might get half that?
Cleaning up the aerodynamics can have benefit. Such as those large side mirrors exchange for smaller size. Get truck lower to ground and put an air dam to keep air from going under vehicle. Bed shell or bad top can help some small amount. It all adds up. Carrying excess weight does not help mileage either.
The benefits to lower rpms are more than just mpg, it also makes it quieter inside the cab, less wear on engine, runs cooler, etc.
NewFordUser20
20
04-05-2016 12:42 AM
walkerrim
01-17-2005 09:13 AM
