98 f150 4.2 to 4.6 motor swap - Ford Truck Enthusiasts Forums
Old 01-08-2012, 11:43 PM
98singlecabshortbox 98singlecabshortbox is offline
98singlecabshortbox is starting off with a positive reputation.
hey i have a 1998 f150 4x4 5 speed with the 4.2 and i can get a 1997 f 150 2 wheel drive 5 speed complete parts truck with the 4.6 windsor in it and i am just wondering if anyone knows if it will drop right in or what?? thanks
Old 01-16-2012, 11:55 AM
Longdistancetrucker's Avatar
Longdistancetrucker Longdistancetrucker is offline
Longdistancetrucker is gaining momentum as a positive member of FTE.
while it will fit right in the "engine cavity", you will have to do some minor modifications to secure it to the frame, the radiator asembly and auxiliary "radiators" / coolers will give you some trouble, therefore you would have to modify the placement of them
good luck...
Swap a 4.2 V6 with 4.6 V8?? jimmerf79 1997 - 2003 F150 6 07-24-2016 12:03 PM
4.2 tach addition Josh Picard 1997 - 2003 F150 2 05-17-2016 08:41 PM
97 F150 4.2 JIMMY712 1997 - 2003 F150 1 12-20-2014 03:04 PM
Engine swap for 98 F150 4.2 with cracked block damarble 1997 - 2003 F150 13 09-04-2013 05:54 PM
98 F-150 with 4.2 V6 to 4.6 V8 3rdgear Engine Swaps 12 02-11-2013 12:48 PM
Tags
150, 1998, 2004, 302, 42, 42l, 46, 50l, 98, diesel, engine, f150, ford, heritage, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
