fuel system problem on 86 f250 carbed 460
#46
Well right now im trying to get the battery fully charged so I can test the volts on the inertia switch, oil pressure switch, and fuel pump relay so I can find the problem. I can't test them right if the battery isnt fully charged. Also I have to drop the tanks out to check the pumps them selfs
#47
Ok so its been nothing but snow, rain, and flooding here in oregon so its hard to work on the truck lately. So I checked the battery and it only had 9.5v so I charged it n it has 11.8v but still won't start. I replaced the starter and checked the starter solenoid and it was good. It did start when I put a friends battery in it, but if my battery is still "good" why won't it start?
#48
#49
https://www.ford-trucks.com/forums/7...tank-leak.html
I have a mechanical pump, not the in-tank pumps many have, but the basics are the same.
#50
Oh, wait. There's another possibility: Something in your truck is pulling enough current to drain your battery and to keep the charger from being able to fully charge it. Try pulling the ground cable to charge the battery. If you can then get it charged to 12.8 volts you have something pulling quite a bit of current.
I haven't gone back through this thread to see if we've been over this before, but: Put your DVM in the 10 amp mode if it has one. That will probably require moving the red probe to another connection, marked 10 A. Then put the red/positive probe on the negative cable and the black/negative one on the negative post of the battery. The meter will tell you if you have a drain, but anything that scale will show means something is wrong.
#51
But, for battery connections, grounds, etc it works well. It certainly won't wash off and since it conducts it actually helps make the connection.
Not all anti-seize are electrically conductive, but as long as you use one like the Bostik Never-Seez that is it's fine to use on things like battery connections, though personally I only use it ground connections at the frame and such, and on spark plug threads.
For at the battery and all other electrical connections like light bulbs, disconnects, etc., I use dielectric grease because it's not electrically conductive.
One place you don't want to use anything though is newer O2 sensor connections because the connection needs air to get correct readings.
#53
For the actual battery terminals I can't really think of any reason why you can't use something conductive. I pretty much only use Never Seeze and dielectric grease. Never Seez is pretty messy and a pain to get off, so that's one reason I don't use it on battery terminals. That, plus habit. I just use dielectric grease on electrical connections. With the exception of ground connections at the body and frame, where I use Never Seez.
zuczis
02-11-2017 01:59 PM
BCO2JCO
03-18-2008 05:06 PM
