1 bbl on 4 bbl intake
Old 01-08-2012, 09:39 AM
1983F1503004x4's Avatar
1983F1503004x4
1983F1503004x4 is offline
I've been thinking of benefits to using the 1BBL Carter YF on the Offenhauser C manifold. Your power would go up because of increased air flow, you can still use the Offenhauser with the stock exhaust manifold, and there's better fuel distribution.
I was thinking a 1 to 2 adapter on top, then a 2 to 4 adapter on the bottom, with a 1bbl sitting on top of both adapters.
One barrel to Two Barrel Carburetor Adapter
Amazon.com: Mr. Gasket 1933 2-Barrel to 4-Barrel Carburetor Adapter Kit: Automotive
I myself don't want to do this. I'm eventually going to go with a 4bbl, but wanted everyone's thoughts on the idea. Also, throwing it out there in case anyone wanted to know.
Old 01-08-2012, 10:14 AM
creativecars1's Avatar
creativecars1
creativecars1 is offline
Since you are only going to be as strong as your weakest link, you will limit airflow with the 1bbl. Then loose all intake velocity as it drops into the intake, and bottle it back up as it hits the ports in the head. I dont believe it would perform great, but it may get you by until you can get the 4bbl on there. If you save your money on all the adaptors and gaskets it may be easier to buy the carb. Just my .02 worth.
Old 01-08-2012, 10:25 AM
1983F1503004x4
It was really just an idea. I wasn't actually going to go through with it, but what you said makes sense.
72Highboy4x4
08-28-2022 03:30 PM
winginit
07-08-2015 10:39 PM
rustywheel68
12-30-2010 11:07 AM
04F150N56F100
12-03-2010 03:42 PM
calazo
20
09-01-2004 10:24 PM
Quick Reply: 1 bbl on 4 bbl intake
