Stock master cylinder brake pressure switch Question - Ford Truck Enthusiasts Forums
Old 01-07-2012, 11:59 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
So I have been taking advantage of the nice warm weather we've been having and got the 53 C600 MH mostly rewired.
started out as just gonna replace the light switch that broke and a couple of leads off the ignition switch that snowballed out of control and now mostly all of the wiring has been replaced. should have just made a nice clean harness or ordered one but no, it looks like a huge rats nest of new wires under there now.
Anyway. To the question, Initialy I was not getting any current through the MC pressure switch until I cleaned the contacts up with acetone and emery paper, then they worked but only when I really pushed hard on the brakes, (they are a little spongy, need to bleed the vac assist brakes and all to make sure it's good) the running light s were also working fine. but after I finish hooking up my turn signals (completely seperate lights and lines etc) the tail lights are coming on but I was not stepping on the brake and the running lights are turned off.???
I assume the MC pressure switch is bad (stuck) making the contact so the lights stay on?? but if so wouldn't they be really bright like when stepping on the brakes? or maybe it's just a weak contact?? confused and really didn't want to have to swap that pressure switch and go through bleeding all the lines.
Maybe I need to go look at how I wired the light switch again....
Old 01-08-2012, 12:30 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
If you are using the standard dual element bulb the inner filament is the brake light and the outer filament is the running light. You should be able to tell which filament is iluminated. A further test would be to disconnect the wires from the brakelight switch and connect them together. Does the inner filament light up?
Old 01-08-2012, 04:11 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C1AZ-13480-A (replaced 0A-13480) .. Brake (Stop) Lamp Switch (Motorcraft SW-24) / Available from Ford and a gazillion autoparts stores.
Applications: 1940/66 FoMoCo vehicles with Hydraulic Brakes.
This pressure activated switch is notorious for getting gummed up with dirty brake fluid. When this occurres (very often), the little charmer no longer works.
Old 01-08-2012, 09:04 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Here's a discussion on this topic from the ford flathead board
Ford Flathead V8 .. 1932 thru 1953 • View topic - pressure brake light switch
Old 01-08-2012, 09:35 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
The pressure activated brake switch on these old pieces is well known for both internal failure and external failure. Contaminants, corrosion to the outside terminals lead to the failure you initially experienced. Like ND said, internal crud leeds to failure of the switch. DOT three brake fluid being hygroscopic draws moisture which exacerbates the problem.
These switches should activate with very little pressure and turn off when the pressure is released. You want the switch to activate when you roll up to a stop with the brakes applied easily so as to notify following drivers of your intentions. It is also necessary that the switch turn off when no pressure is applied or you will have a dead battery. The switches are cheap.
Old 01-08-2012, 11:29 AM
jmadsen's Avatar
Thanks guys, it looks like maybe I should just install a mechanical lever style switch, I was initially thinking I would do that but then it started to work, so back to square one. I don't really want to re-bleed the entire system otherwise I might try a pressure switch again.
now to just find the right manual switch.
Old 01-08-2012, 12:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I've had no problems with the pressure switch. The problem I see with a mechanical switch is that there is relatively small movement of the parts of the linkage when the brakes are properly adjusted, and light braking. At the pedal pad, I doubt there is 1/2" of movement after adjusting my shoes, and that is the point of most motion. You can't put a switch there, obviously. Mechanical switches I am familiar with need more motion than that. I suppose you could loosen the pushrod and make more play down below, but I like them the way they are.
Old 01-08-2012, 03:57 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
if you are going to replace your brake switch at the master cylinder, Mid-Fifty sells one that takes less pressure to turn on...
Brake Dist block orientation / power drum expectations markeyd 1961 - 1966 F-100 & Larger F-Series Trucks 14 06-02-2016 08:53 PM
BRAKE Warning light (not the ebrake) Mitch Eckler 1968-2013 Full Size Vans 20 04-08-2016 10:18 PM
BRAKE LIGHTS littleredford69 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 02-27-2016 02:13 PM
Diagnosing Brakes / Master Cylinder with Low Pedal AL` 6.0L Power Stroke Diesel 19 02-17-2016 02:54 PM
Reverse light issue on a 76 Batman7593 1973 - 1979 F-100 & Larger F-Series Trucks 17 05-19-2014 08:30 PM
Tags
1952, 2001, brake, company, excursion, f1, f150, fluid, ford, light, motor, powered, pressure, senser, stock, switch, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
