Add-A-Leaf on 2WD Works Well! Over 2 inch Lift
Old 01-07-2012, 10:44 PM
jaclins's Avatar
jaclins
jaclins is offline
Just installed a set of ProComp Add-A-Leafs to the rear leaf packs of my 2000 2WD 5.4 X. Not an easy task to do, took most of the day. However, in the end it lifted the rear end 2 1/8 inches! The truck looks great, and rides great. Handles better. ProComp model is 13128, and I highly recommend. Not sure if you can beat a 2 inch lift for $100.
Old 01-07-2012, 10:54 PM
njneer1's Avatar
njneer1
njneer1 is offline
It's amazing how that one spring stiffens up the whole pack !
Old 01-07-2012, 10:56 PM
jaclins's Avatar
jaclins
jaclins is offline
I really thought I might actually get an inch. But they were right, got the 2 inches. The actual ride feels the same to me, but it handles better around turns, doesnt sway as much as it used to.
Old 01-07-2012, 11:00 PM
njneer1's Avatar
njneer1
njneer1 is offline
Same experience I had with it.....good ride less sway....handles much better
Old 01-07-2012, 11:34 PM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
I wonder the difference in rear springs on the 2wd vs. 4wd? What would that do on a 4x4?
Old 01-07-2012, 11:36 PM
jaclins's Avatar
jaclins
jaclins is offline
Not sure. Does the 4x4 have a leafpack like the 4x2?
Old 01-07-2012, 11:42 PM
njneer1's Avatar
njneer1
njneer1 is offline
Mine is 4wd......I am betting it's the same.....but the 4wd had a block
Old 01-08-2012, 08:07 AM
JumpinJoe's Avatar
JumpinJoe
JumpinJoe is offline
Same here?
Old 01-08-2012, 08:46 AM
Joe28443's Avatar
Joe28443
Joe28443 is offline
Joe28443
That sounds like a plan
Old 01-08-2012, 09:39 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
No pics?
Does your 2wd have a rear sway bar? I am gonna be doing some suspension stuff with my 2wd but I want it to sit flat. I'm not a fan of huge rake.
Old 01-08-2012, 10:11 AM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,075 Likes on 554 Posts
I'd like a 2" lift myself. What's the answer for lifting the front the same amount?
Old 01-08-2012, 10:22 AM
EXv10's Avatar
EXv10
EXv10 is offline
I'm wondering how adding a small leaf would work on the front of a 4WD, I only need another inch so it won't bottom out as easily.
Old 01-08-2012, 10:26 AM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
I had the local spring shop add a leaf to the front and rear and got about what everyone else is saying. It raised it between 2"-3" both front and rear.
Old 01-08-2012, 12:57 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
One of my threads from Feb 2010:
https://www.ford-trucks.com/forums/9...ml#post8492932
Originally Posted by Stewart_H
Most two-wheel drive leveling spacers are made from polyurethane or UHMW. I was checking out ebay recently and came across a kit where the spacers were made from billet aluminum.
FORD F250 F350 SUPER DUTY 2WD 2" LEVELING LIFT KIT FB2 : eBay Motors (item 110488105005 end time Mar-01-10 08:17:44 PST)
Pretty shnazzy!
Stewart
A post from that thread:
Originally Posted by canister
Here are some pics. I have 265/75/16's (for now, need to save up for 285's) and have about 7" from the top of the wheel to the fender and about 4" on each side.
Pay very close attention to the thread links I posted in post number 21. Clearancing of the ball joints will be needed.
Here's the post:
Joe, here are Pete's previous threads on his adventures installing his kit.
https://www.ford-trucks.com/forums/8...ml#post7912749 <~good pics at the bottom of the thread.
https://www.ford-trucks.com/forums/8...ml#post7764878
Stewart
Stewart
Old 01-08-2012, 01:10 PM
Stewart_H's Avatar
Stewart_H
Computer controlled by Ford at the factory. 2-wheel drive trucks have the same rear springs as 4-wheel drive trucks, it just depends on which spring Ford put on them.
I know my 2-wheel drive F250 had the same OEM rear spring as my 4x4 Excursion before I did the swap.
Stewart
Quick Reply: Add-A-Leaf on 2WD Works Well! Over 2 inch Lift
