77' f150 6.0 engine swap - Ford Truck Enthusiasts Forums
Old 01-07-2012, 10:20 PM
shorty2tall shorty2tall is offline
shorty2tall is starting off with a positive reputation.
ok so my plan is to do a engine swap on my 77f150.
Before i start i need some info.
Has anyone done a ford v8 diesel swap in there truck?
Is the frame on a 02 SD the same as what frame would be on a o3-o7 truck? reason i ask is i have a 02 to get a few measurements off.
i know ill need to swap my axles to dana60's what is the best year to find them from? if any one has info or know where i can find info please post links.
i will be using a zf-6 any info on how any one has done a zf-6 in theres cummins swaps would be awesome.
thanks guys!
Old 01-08-2012, 10:35 PM
bump
ok well anyone have info on dana 60 swap to a f150 to support the weight?
Old 01-08-2012, 11:35 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I'm not sure if anyone has swapped a 6.0 into anything. I do know there is a ton of wiring involved in a PSD swap.
Jeff's Bronco Graveyard has radius arm mounts for the D60, you will have to figure out what to use for springs though as the 6.0 is heavier than anything Ford put in the front of that truck from the factory.
91 F150, swapping from auto to ZF Bootlegger's Deluxe 1987 - 1996 F150 & Larger F-Series Trucks 0 10-23-2016 09:46 PM
Zf6 swap Danjonp 1999 - 2003 7.3L Power Stroke Diesel 17 10-01-2016 03:22 AM
2WD ZF5 TO 4WD ZF5 idisam6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 09-03-2016 09:52 PM
NEED HELP WITH 6 SPD SWAP! REGULAR CAB LONG BOX 2 WHEEL DRIVE 1982_f150 1999 - 2003 7.3L Power Stroke Diesel 17 08-29-2014 08:25 AM
ZF5 swap landon460 1987 - 1996 F150 & Larger F-Series Trucks 10 07-25-2009 07:53 PM
Tags
1977, 50, 60, 77, cummins, diesel, engine, engines, f150, f250, ford, fords, motor, swap, swaps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
