hey everyone, ive been doing some work to the truck and ive been shopping for a lift now, i want 6 inches of lift and i was wondering whats the best way to do this being the most price efficient, i found some block kits and heard about shackle flips but wouldnt know how to go about it, let me know what you think how i should go about it. think cheap no body lifts though
Never use blocks in front! You should have a factory block in the rear. I used the Skyjacker 6" system, it's all 4 springs and does retain the factory rear block. Front drive shaft needed to be lengthened and I also had to use a drop pitman arm, drop drag link and a steering arm spacer to get my steering right but it was all worth it. Now i just need a step to get in it
heres a picture of what my truck looks like now, i dont have the drop adjustable drag link so my steering is all messed up. but i am currently driving the truck
im getting a pretty bad clunk when i shift from park. also when i decelerate. i have some play in the rear end, i dont know how much is allowable but its a loud clunk. my u joints are good the only other thing is the splines of the slip joint on the drive shaft have play. what do you guys think is my problem
Sounds like you might need the rearend backlash checked......I would think a little slip spline wear would not make a loud clunk, but a R&P issue would.
