help me identify this!
Here are numbers that I can find on it
Eng #:23L242
PN: F3TF-2C018-AB A 0816357 CIV
SINGLE REAR WHEEL ONLY
that iss all on the blue part of the sticker
on the back of the connector in red it has the following
93 43
E7ZB-14A624-AA
I assume this will hoppefully resolve the issue of my ABS light switching on intermittently and ultimately my no cruise control situation?? if so YAY!
Eng #:23L242
93 43
E7ZB-14A624-AA
i will, but I want to say that if your horn isnt working that may possibly be related to something else, but i will post back so others will have this as a resource to use
Cruise servo locking up is a common problem. Search will turn up alot.
If the electronics on top of the servo are unplugged the horn wont work. But the clock spring could also be bad since the horn isnt working.
Jaime. Unplugging that will result in no rear ABS brakes. Have you tried pulling the codes first? That could tell you exactly whats wrong.
What year is your truck? Does your speedometer work? If everything is working but the horn and the cruise then you have a bad clockspring in your steering wheel.
its a 95 and horns were working, cruise stopped working months before my horns died, so I replaced the RABS and now cruise is working properly no more ABS light, now I just need to fix my horn...
It will not. The cruise and the RABS are two independent systems. If your cruise isn't working and you have the ABS light coming on intermittently then it's either the VSS on the rear axle, the wiring to it, or the PSOM in the dash.
I been kicking this dead horse for a while...My speedometer doesn't work, (only when it rains it does,) my rabs light is on and the brakes feel like an anvil once in a while. Changed rabs mod, vss in rear...talked nice to it, put a gun to it's dash, still devoted to her for it's the only issue we have.
ok just to update everyone on my horn/ABS not w0orking correctly, the RABS fixed the cruise/ABS light issue, I checked my horns and found that they had over 15 years of rust on them (the horns were literally rusted and the bracket was following suit, so I took a rotery tool to the bracket and cleaned it up, also used rust remover, and then installed brand new horns and the horns now are working correctly. so as far as MY specific situation I have successfully resolved the issue(s)
