Lets talk 6.2L performance
If it's warrantied by my dealer, I'd still do it!!
My warranty is the ONLY reason I haven't been messing with the truck. If the dealer covered it all, oh boy, it's ON....
In the spirit of this topic (HP), here's a little video of our test drive when the old man got his sand rail together (this was 5-6 years ago, car still looks brand new). Turn up your speakers!
I was perusing Roush's site and came across this.. (delivers over 700hp) Mike, it looks like you might have a couple of guinea pigs here... lol
F-150 Supercharger 6.2L Tuner Kit (2010-2012)
I dont know who will have one for 6.2 raptor first Whipple or Roush.
I see its on whipples site now http://www.whipplesuperchargers.com/...sp?ProdID=1274
ProCharger has a kit for the Raptor 6.2L that yields 496 RWHP (see link below). With a 20% loss of HP to the rear wheels, that's 620 HP at the engine. The Roush kit should yield similar results but could be greatly enhanced with a few upgrades. My only concern would be the ability of the internals (crank, rods, pistons) to endure the stress of say 10+ PSI over time. Does anyone know if the 6.2L internals are forged?
ProCharger F-150 SVT Raptor 6.2L 2V HO Supercharger Kit 1FS211-SCI
The total cost of the base Roush kit would be in the $7,500 to $8,000 range including installation cost. Start replacing the internals with forged components and the cost escalates very quickly!
https://www.ford-trucks.com/news/idx...AS_ENGINE.html
Key features of the new 6.2-liter V-8 gasoline engine include:
*Cast-iron engine block and four-bolt main bearing caps, with cross bolts, for durability
*Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder
*Cast-iron crankshaft, with dual-mode damper
*Forged steel connecting rods
*Cast-aluminum pistons, with cooling jets
*Single overhead camshaft with variable valve timing and roller-rocker shaft valvetrain
*Magnesium cam covers for lighter weight
*Stamped-steel oil pan
*Composite intake manifold
*Stainless-steel fuel rail; port-fuel-injected; mechanical returnless fuel system
*9.8:1 compression ratio
*E85/flex fuel capable
Details of the motor:
2011 FORD SUPER DUTY BOASTS 6.2-LITER GAS ENGINE .: News
BLUE = GOOD
I guess that running 6-7 PSI would be acceptable with the OEM internals.
As was posted earlier, Roush Performance is a partner with Ford Motor Company and generally designs SC kits that are warranty compliant. I wish that FMC would take the time and minimal amount of $$$ to use forged internals in all of their engines.
#28
The cast crank and high silicon pistons are the same spec used in the 4.6 3V and 5.0 Mustang motors and they are boosted all the time. As long as we keep the tune conservative and boost numbers on this side of insane there's no reason to think it would survive for a long time.
And are we sure that the crank is cast? I though I read somewhere that is was forged
