2002 150 firing order - Ford Truck Enthusiasts Forums
Old 01-07-2012, 04:06 PM
chris1x chris1x is offline
chris1x is starting off with a positive reputation.
I have a 2002 f150 supercab with a 5.4 triton,i am getting a code saying that number 6 cylinder is misfiring what is the firing order?
Old 01-07-2012, 04:12 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
6 would be the drivers side second back from the front.
Old 01-07-2012, 08:18 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Standing in Front of the truck.
----------- 5 - 1
Driver side--6 - 2
----------- 7 - 3 Passenger side
----------- 8 - 4
Back of engine.
Old 01-07-2012, 08:47 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE chris1x.
Cylinder 6 is on the driver's side of truck, second back from the front of the truck.
Old 01-07-2012, 10:40 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
You may think it nit picking but it's not the fire order.
It's the cylinder physical position designation as a reference Ford uses.
Actual fire 'order' is quite different.
The injectors follow the same fire order but operate a short time before ignition in each cylinder when the intake valve is open, for obvious reasons.
2002 F150 Shocks bass-n-fire 1997 - 2003 F150 0 02-14-2017 07:31 PM
cylinder numbers and firing order 7.3 powerstroke info please .. F-WhiteThunder 1999 - 2003 7.3L Power Stroke Diesel 13 07-06-2014 01:27 AM
Firing order for 2002 E-150 ilkefords 1968-2013 Full Size Vans 1 08-20-2009 07:28 AM
firing order cotterpin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-27-2008 09:16 PM
firing order for 300 6 cylinder 89 f 150 ecbooks Ford Inline Six, 200, 250, 4.9L / 300 0 01-23-2003 09:01 PM
Tags
02, 150, 2002, 250, 42, 54, cylinder, f150, fire, firing, ford, order, triton, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
