Starter bendix stuck in engaged position
I've got a 57 F100, and when I picked up the rebuilt starter to put it back in I slipped the bendix into the engaged position. I can't figure out how to disengage it and move the gear away from the starter housing.
Having it in this position is making it tough to remount the starter, as the gear and flywheel engaging seems to shift it slightly out of line. Can anybody help me disengage it?
Received 1,351 Likes
on
Booster cables didn't loosen it. Some pretty sparks though.
I can't move it back into position by hand - that's the problem. It's locked into what seems to be the engaged position and won't move back up the shaft.
I took a picture of it to confirm that it is in the engaged position, but now I can't find my card reader, so I'll post that eventually.
on
I haven't been into an old starter in the last 45 years. I seem to remember
putting something like a piece of card board, like a match from a matchbook
up into the one spiral groove and getting it to ride up over the detent stop.
I then had to be very careful not to let the drive extend while handling
the starter. I may be way off as 45 years is a long time and the memory
is slipping.
is slipping.
on
I ordered a starter to flywheel housing seal to replace the crumbled one I took off, so I'm hoping that difference in position makes just enough of a change to get the bolts threaded.
As best I can tell, this starter drive pulls the gear into the flywheel to start, rather than pushing it out into it. Given the placement of the flywheel and the shape of the drive, I don't think there's enough clearance for it to work the other way around. Am I just way off base here?
Solved
As soon as I did that the bendix retracted easily.
is slipping.
is slipping.
Skoob
10-30-2021 08:28 PM
WaveyDavey1980
04-18-2019 09:31 PM
gollygwagen
13
05-22-2008 09:03 PM
