Scangauge "EGR Valve Position Measured"
there is also a "EGR Desired" and when I am showing both this and the "Measured", it appears that it can be telling you how well the valve is actually meeting the setting command, which might inform if the valve is lagging or failing to open or close or whatever.
Having only my own to compare I don't know what normal should look like. It always eventually measures whatever is desired, but it's not instant and there are times when measured will spike way off what desired is. Makes me think, just from watching it, that it might be getting 'sloppy', being pushed around by the flows rather than holding what it's told to do.
Just an impression, I don't know.
Sorry for chiming in but do any of you no what the EVD and the ETP on the scangauge shoud be reading at idle? I can not got the EVM to read on truck for some reason. But I am trying to pin point a problem with my truck and this thread caught my attention. My scangauge is showing my EVD to be 11 @Idle and my ETP is -4093 @ldle and it only goes up to -4094 when I rev up the rpms? Sorry for the hijack but i am going crazy trying to figure this thing out!
I'm not sure what all these mean, you guys are seeing the readings. I got these OP values from a Tech. I just hope I separated them correctly. At the bottm you will see how I got them.
Key On, Low Idle, High Idle, Operating Range Measurement, Units Description
EGR EVAL
KOEO=NO LI=NO, HI=NO YES, OP=NO/YES, EGR Evaluated
EGR DC#
KOEO=0 LI=0 - 15, HI=32, OP=0 - 44 PERCENT, EGR Duty Cycle
EGR_F
KOEO= NO FAULT, LI=NO FAULT, HI=NO FAULT, OP=0 - 44 FAULT/NO FAULT EGR Status
EGRVP
KOEO=0.8, LI=0.8 - 1.0, HI=1.3, OP=0.6 - 3.5 VOLT, EGR Valve Position
EGRVPDES
KOEO=0, LI=0, HI=9.72, OP= 0 - 14 PERCENT, EGR Desired
EGR EVAL NO NO NO YES NO/YES EGR Evaluated
EGR DC# 0 0 - 15 32 0 - 44 PERCENT EGR Duty Cycle
EGR_F NO FAULT NO FAULT NO FAULT 0 - 44 FAULT/NO FAULT EGR Status
EGRVP 0.8 0.8 - 1.0 1.3 0.6 - 3.5 VOLT EGR Valve Position
EGRVPDES 0 0 9.72 0 - 14 PERCENT EGR Desired
EGR EVAL
EGR DC#
EGR_F
EGRVP
EGRVPDES
From a list of Xgauges. Sorry, I don't have all the operating values on these.
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Throttle Position Control Signal
TXD: 07E022096C
RXF: 04620509066C
RXD: 3010
MTH: 00647FFF0000
NAM: ETP
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Desired (%)
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
TXD: 07E022096C
RXF: 04620509066C
RXD: 3010
MTH: 00647FFF0000
NAM: ETP
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
these are the ones you want to watch
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
right now I'm running with the EGR connector disconnected. My '05 has a very early flash and this does not cause a CEL or fan problems. EVD still varies with conditions, but EVM always reads 100.
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
