Problems caused by idling? - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 03-02-2012, 03:52 PM
dmags dmags is offline
dmags is gaining momentum as a positive member of FTE.
I would not say my old Superduty (6.0) saw -50 but it was like -35 in Canada when I was up there and it didn't sound good after sitting out a couple of days when it was that cold.I wouldn't even consider driving it until it built up some heat under the hood.I think it took almost a half hour before it sounded normal.
  #77
Old 03-27-2012, 12:11 AM
Northof62's Avatar
Northof62 Northof62 is offline
Northof62 is starting off with a positive reputation.
I was finally able to talk to a guy who drives a 6.7 up here on the north slope. His company has twenty of them. He said they have been running them for two years. I guess they have had a ton of problems from excessive idling(8-12hrs). They have their idles set between 1800-2000. I wasn't able to talk to him very long but what I got out of it was that these engines don't handle idling well(as many here have stated). That being said, he told me they still love the trucks. I'm trying to find out who wrenches on their trucks so I can get more detailed info.
  #78
Old 03-27-2012, 08:36 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
8-12 hrs per day?
  #79
Old 03-27-2012, 08:49 AM
Northof62's Avatar
Yeah. When it's forty below, as it is today, everybody up here ides all day. Our trucks are our offices, break shacks, etc. A good proving ground for Ford trucks!
  #80
Old 04-21-2014, 10:34 AM
Apikapak Apikapak is offline
Apikapak is starting off with a positive reputation.
10 + hrs of idling
Planning to buy a 2015, wondering if any changes have been made since I will be idling for periods of 10+ hours a day in the winter.
Pipelining has a lot of seat time and extreme cold weather...
Might have to get a gas engine worst comes to worst but would rather enjoy the torque of a diesel
  #81
Old 04-21-2014, 11:27 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
WoW!!! that's cold ....
my fix is to not live/work there
  #82
Old 04-21-2014, 11:52 AM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
Originally Posted by CornTruckDriver View Post
I just saw my hours. It says 130 hours and 40 idling. I do not believe it. They must count every stop light and drive through . There is no way I have idled this truck for almost 1/3 of the time I have driven it.
If your not moving and the truck is running then you're idling, like it or not that's the facts of life..
  #83
Old 04-21-2014, 06:40 PM
kper05's Avatar
If you need the power of the diesel, well then that's what you need to do your job.
At a minimum, wire up SEIC to an upfitter switch for high idle, I'm thinking at least 1,400 RPM.
Get the Edge Insight CTS so you can monitor soot level in the DPF (and manually run active regeneration if absolute necessary).
If you'll be hauling heavy often enough, that will be helpful to keep things cleaned out.
Get the long bed for the larger fuel tank.
I like the factory remote start.....But Nipperdog 6.7L Power Stroke Diesel 35 01-03-2015 11:25 AM
1996 7.5 f250 idle problems charecter1 1987 - 1996 F150 & Larger F-Series Trucks 7 05-28-2014 07:07 AM
IAC valve confusion wingzam 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 7 01-16-2013 08:00 PM
1986 E250 rough idle, stalls 351 carb 28k econobox 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 26 01-04-2013 11:51 PM
What RPM's do you idle at? 04whiteXLT 1997-2006 Expedition & Navigator 15 03-20-2005 11:12 AM
Tags
60, cold, commutes, diesel, driving, f250, f350, ford, hurt, idle, long, pose, problems, short, stacking, takes, time, warm, wet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
