Harmonic Balancer Removal/Installation - Page 2 - Ford Truck Enthusiasts Forums
Old 03-04-2012, 10:11 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Originally Posted by Mario81587 View Post
I don't mean to hijack this thread, but I just have a question about the removal process. I spoke with a technician at Ford and was told that it didn't matter if the crankshaft rotated while I was trying to remove the harmonic balancer bolt. I rotated it a little bit and haven't successfully gotten it off. I ordered a chain wrench to hold it in place and I'm waiting for that to be shipped to me. Did I screw up the timing on the engine by rotating the crankshaft? It's a 2002 Mercury Mountaineer AWD V6 (4.0 SOHC). Thank you for any advice.
- Mario
You're fine, no worries.
BTW you're in the entirely wrong forum, you should really ask HERE.
But, welcome to FTE, anyway.
Old 03-08-2012, 10:21 AM
Wyowanderer's Avatar
Wyowanderer Wyowanderer is offline
Wyowanderer is gaining momentum as a positive member of FTE.Wyowanderer is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BaronVonAutomatc View Post
The tool threads into the crank and uses a spacer/nut to force the balancer into place.
I say respectfully,
It's a nice tool, but absolutely unnecessary for the installation of the balancer. The factory doesn't use one, and I don't either. And I've installed literally dozens of them with the crank bolt, never having had a problem. If you like having the tool and you can afford to buy it, by all means do it. But the only reason you'll need a special tool to install the harmonic balancer on this engine (it has a grade 8 fine thread 3/4 inch bolt-with a tensile strength of 130,000 psi) is if the crank snout or bolt is damaged in the first place.
Here's how I've done my dozens:
I screw the bolt into the crank to make sure the threads are good, and if they're not I deal with that first.
Put a tiny amount of silicone sealant inside the balancer hole and a little sealer on the crank snout where the woodruff key (some cranks have just a regular key) is in it. These two bits of sealant will keep it engine oil from leaking past the snout/crank interface,and was done at the factory. Use caution to use a TINY amount- you don't need much, and any extra that gets inside the engine will do more harm than an oil leak.
Line up the balancer onto the clean crankshaft, tap the center of the balancer with a soft blow hammer, and screw in the bolt with the washer on it until it bottoms out. Tighten the bolt up, check the torque, and you're done.
Now I don't intend to minimize what BVA says. We have different opinions, that's all.
Naturally, mine is right
The Answers only Thread. sky Cowboy British Columbia 54 04-20-2016 12:43 PM
What thread pitch for oil filter? DirtyLarry 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-08-2016 10:05 PM
Front wheel wont come off! Drivers side front - all the lugs are off. Suggestions? 93XLT150 1987 - 1996 F150 & Larger F-Series Trucks 16 02-19-2011 09:47 PM
HELP! I broke off the fuel filter flush with the carb :-( MikeS29 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-09-2010 04:48 PM
Problem with spindle threads Dakaty Brakes, Steering, Suspension, Tires, & Wheels 5 07-07-2005 02:27 PM
Tags
1956, 1996, 1999, 50, balancer, bronco, diesel, f150, ford, harmoic, harmonic, illustration, ll, noise, removal, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
